View Full Version : Which LS swap kit for first gen camaro?
toofun
06-16-2019, 04:30 AM
Getting ready to do an LS swap and want to know opinions on swap kits that are out there. UMI, TRANSDAPT, HOLLEY, TEXAS SPEED, speed tech, etc... I see prices very greatly between all of these companies when you look at their engine mount, oil pan, header and other components. Which is the best bang for your buck. I don’t want to cheap out and chance a problem but also don’t want to break the bank either. Opinions on these companies or any company I forgot? A combination of companies? Any opinions appreciated
mark
tootun
dhutton
06-16-2019, 05:02 AM
Holley.
130fe
06-16-2019, 05:03 AM
The Holley stuff works well with the factory subframe. No tunnel surgery with a T56 magnum either.
Toddoky
You’ll get the most relevant answer by adding some specific information about your swap, such as what transmission, accessory drive system and A/C system (if any) you are planning to use and whether you are using any aftermarket steering and/or front suspension components.
toofun
06-16-2019, 05:51 AM
Normal front drive system that comes on an LS three motor out of a 2010 Camaro LS three I am getting already has the head swap as well as intake swap. There was an AC on the engine I’m getting but he’s keeping that I have a vintage air AC unit that I plan on swapping onto it I have Detroit speed suspension in the front normal steering I plan on using a T 56 magnum but do not want to perform surgery on the tunnel if possible be all the systems look nice and complete but they are very expensive
dhutton
06-16-2019, 06:08 AM
Good luck using the factory Camaro accessory drive. That alternator is going to hit some stuff on a stock subframe pretty hard as far as I know....
Detroit Speed subframe or bolt on DSE parts on a stock subframe?
Don
toofun
06-16-2019, 08:47 AM
Don
bolt on DSE.
DT69Cam
06-16-2019, 09:10 AM
Holley
John McIntire
06-16-2019, 02:16 PM
Holley
