ryeguy2006a
06-06-2019, 08:41 AM
Hey all,
I'm fund raising to get one of the new Holley Terminator X units, so I'm selling off some of the stock LS harnesses, ECU's and a wideband kit I've been holding on to. I've also got some other misc. LS parts that I'm not using to help fund the cause.
First up is a stock 2002 Harness/ECU/TAC/Pedal/Throttlebody matching setup that I personally pulled off of a friends Escalade. It's completely stock and only had two cut connectors. I've soldered and heat shrunk them back together so it's all ready to be converted to stand alone. $300 plus actual shipping.
https://static1.pt-content.com/images/pt/2019/04/32620959067_608a171887_b-1.jpg
Second is the personal engine harness and 99 LS1 ECU that is on my 1968 Camaro swap currently.It functions 100% and has been converted over to stand alone using the LT1swap.com diagrams. It is set up currently for an 85mm MAF with integrated IAT and for a t56 with only reverse lights, reverse lock-out and VSS plugs. The tune on file is also the standard stand alone items removed; VATS, Rear 02's, CAGS, EGR, AIR, and etc. I can also do other basic tuning if needed or can swap back to the 5.3 file or stock LS1 file I have on my computer $450 plus actual shipping
https://static1.pt-content.com/images/pt/2019/05/47766204412_691e20dfc6_b-1.jpg
And last, I have a brand new Innovate LC-2 kit in the box. I've only opened it to check it out and will include everything you would get new. $125 shipped.
https://static1.pt-content.com/images/pt/2019/06/27918581939_bba7c4f79e_b-1.jpg
Before I sell the swap harness that's currently installed on my Camaro, I'd need to have the Escalade harness and wideband sold. I would also need to have a few weeks to carefully pull the harness from my car (and label for you) as there are about 12 wires that are integrated into the car at this point.
I have some other misc. parts for sale as well.
Some brand new 42lb green giant knock off injectors. $95 shipped
https://static1.pt-content.com/images/pt/2019/06/38799760215_57dedef819_b-1.jpg
LS1 4 corner steam port - $75 shipped
Very good condition truck A/C compressor and bracket $115 plus actual shipping
https://static1.pt-content.com/images/pt/2019/06/24853849427_d9f6cd5109_b-1.jpg
I'm sure I'll find a few other things, but this is all for now. And if you want it all, take the whole lot for $995 plus actual shipping. (not a coincidence that is what the Terminator X costs)
Ryan
Ryan
