View Full Version : Difficulty with lower arm bar Ridetech 67’ camaro
Bullrider
06-05-2019, 03:45 AM
We have a ‘67 camaro and are installing the ridetech four link with a 9” Currie rear end that has all the brackets welded from the factory. We were doing well on all four links but can’t get the lower arm bar on the drivers side to line up on the axle’s bracket to get that 5/8” bolt pushed through. We are very close. Maybe I should unbolt one of the top short bars to get this bottom long 164801bar to line up. Any thoughts? I am hoping the factory welded brackets are not off a little.
btmatt
06-05-2019, 11:22 AM
can you loosen the front perch to get the bolt thru and then re-tighten?
Bullrider
06-05-2019, 12:40 PM
Yes. I called Ridetech this morning and they suggested the same. Will try that tonight. Thanks!
Bullrider
06-22-2019, 08:40 PM
Update-I unbolted one of the top links and I was able to move the axle laterally and it all lined up. Thanks for the help.
