View Full Version : Anyone running cats?
sginphx
05-15-2019, 03:23 PM
Have a stroked LS3 in my Camaro that runs rich. Cant seem to "tune" it out.
Would running a cat help? Also, getting ready to run a 480HP LS3 in my truck so would apply there also. Thanks
badazz81z28
05-15-2019, 03:42 PM
I have thought about it a ton of times! I had my AFR dialed in pretty well on the dyno and you still smell exhaust. They have really good high flow cats, I just need to do it!
ULTM8Z
05-15-2019, 05:54 PM
I've been running Walker highflow cats since about 2004-ish. I got tired of the exhaust smell getting on my clothes and crap like that. Also quieted down the exhaust a little which was an added benefit (at least I considered it a benefit... lol). Didn't notice any drop in power.
cdrod
05-16-2019, 04:06 PM
I'm building a '72 Olds 442 convertible and decided to go with dual cats to minimize the exhaust smell with the top down. I chose DynaTech cats because they have a high-flow, metal core that won't melt down like a ceramic core if they get too hot. I called Dynatech support and the tech said the cores have 300 cells per inch and will flow 396cfm each. He also said the metal cores will light-off more quickly than a ceramic core too. Should be enough flow to support 455cid @ 6000rpm. Here's a link:
https://www.dynatechheaders.com/store.aspx?itemid=3449&pagetitle=catalytic-converters
anguilla1980
05-17-2019, 12:41 PM
Thanks for the link. I have been contemplating this for a few years. Those look like a great way to go.
raustinss
05-18-2019, 03:40 AM
I've always thought they were a good idea , look at the power levels the manufacturers are chucking at us now , all with cats
Mr Nick
05-19-2019, 04:58 PM
If it's actually running too rich, adding cats will not solve that problem. Also, if it's running very rich, the cats may not last long.
JustJohn
05-20-2019, 05:38 AM
Do you have O2 sensors on both exhaust branches or just 1?
cdrod
05-20-2019, 01:49 PM
Agreed! I was told not to run cats with a carburetor because the AFR range is too wide with a carb; so I decided to go with a throttle body EFI system. The AFR has to be very consistent for cats to work properly and survive. If the mixture is too rich, the platinum core will overheat and melt, destroying the cat. Ceramic core cats are much more susceptible to damage from overly rich AFRs than are metal core cats.
sginphx
05-22-2019, 06:12 PM
Yes..running 2 O2 sensors. If I do...I for sure would use metal core over ceramic. Hard to believe more people haven't used them for feedback. Thanks for all the responses so far!
Mr Nick
05-22-2019, 07:29 PM
I plan on adding cats, but my engine burns a little oil and I need to solve that problem before adding them. Burning oil isn't good for catalytic converters either.
Larry Callahan
05-22-2019, 07:51 PM
I really like the idea of running them. After I get my '55 dialed in and stable I will add them to it. I'm glad to hear that it's not that uncommon.
79 Camaro
05-24-2019, 05:44 PM
On my E36 LS swap I added the spun cats after a year of driving only to cut down on the exhaust noise. Don't think you are going to get a way from gas smell with the cats. My TJ LS Swap and 68 C10 LS swap don't smell but they had a good quality chassis dyno tune. Neither has cats.
