Shotaro
05-13-2019, 08:00 PM
My 1970 Camaro has been changed to GM12bolt to ZL1 Brembo four-wheel disc brake, but I would like to improve it because the brake stroke sometimes becomes long. I am currently attaching the 2psi Residual Pressure Valve to the rear, but I would like to know if changing it to 4lb, Gold, w / o Fitting. Will you pull the brake at 10 psi? Or is there any other way to attach the c-clip eliminator? Will the master cylinder review also improve?
164317
164316
164317
164316
