View Full Version : Trunk upholstery
terrydmorgan
05-11-2019, 12:58 PM
After admiring other people’s trunks, I’ve decided to do my own. Bought the plans from Alien Enclosures and started the process a couple of weeks ago. Principally finished today and am quite pleased.
http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/C353A971-1F0A-45A5-94A4-4FB24225DBDA.jpg.html
Cut the bottom out of ¾” plywood and the sides are ¼”
http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/5ECD721F-0DB6-4769-B029-B387CA559C0D.jpg.html
Assembled the pieces outside the trunk, as they are self supporting.
http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/F75C52AD-85A4-4F38-BA44-45337313E9DB.jpg.html
A bit of cutting and adjusting was needed to fit the assembly in my trunk area.
http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/6EA930DB-986C-424C-BB29-FEEF063BD008.jpg.html
Upholstered with ¼” foam and red perforated vinyl. Inserts are 1/32” carbon fiber sheets on ⅛” plywood backer.
http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/2262A1A1-CD0B-40D3-B951-A440CE2F3CD4.jpg.html
http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/48B50EF3-60B3-4E12-95BB-87CB33C97CF5.jpg.html
terrydmorgan
05-11-2019, 01:14 PM
https://static1.pt-content.com/images/pt/2019/05/5ECD721F0DB64769B029B387CA559C0D-1.jpg (http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/5ECD721F-0DB6-4769-B029-B387CA559C0D.jpg.html)
https://static1.pt-content.com/images/pt/2019/05/F75C52AD85A44F38BA4445337313E9DB-1.jpg (http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/F75C52AD-85A4-4F38-BA44-45337313E9DB.jpg.html)
https://static1.pt-content.com/images/pt/2019/05/6EA930DB986C424CBB29FEEF063BD008-1.jpg (http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/6EA930DB-986C-424C-BB29-FEEF063BD008.jpg.html)
https://static1.pt-content.com/images/pt/2019/05/2262A1A1CD0B40D3B951A440CE2F3CD4-1.jpg (http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/2262A1A1-CD0B-40D3-B951-A440CE2F3CD4.jpg.html)
https://static1.pt-content.com/images/pt/2019/05/48B50EF360B34E1295BB87CB33C97CF5-1.jpg (http://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/48B50EF3-60B3-4E12-95BB-87CB33C97CF5.jpg.html)
dhutton
05-12-2019, 03:57 AM
That looks great.
Don
Just 1 More
05-12-2019, 11:28 AM
Great job
minendrews68
05-15-2019, 05:32 AM
Sure took space out of your trunk though.
terrydmorgan
05-15-2019, 09:19 AM
Carl, Agreed on the reduction in apparent space; however, the panels are readily removable (velcro holds the panels in place) and storage is available behind the panels on each end and behind the rear seat. I have a trunk mounted battery setup behind the passenger side of the rear seat, which is hidden by the new trunk panels.
minendrews68
05-19-2019, 07:22 AM
All of it looks really good. I did something similar in my Camaro. I also used the velcro to hold the panels on. I can get to the back of mine easily as well. I also have a bottom panel that covers the "trap" door to the top of my gas tank if I need to do work on it without having to drop the tank. Good job on yours!
Projus
05-23-2019, 02:47 AM
How much were the plans? Sure wish you would have done 2 and sold me one
terrydmorgan
05-23-2019, 11:13 AM
$87.35 with shipping. Couldn't have been much easier. Just cut out the patterns, trace around them on your plywood, and cut out the panels using your jig saw. A minor amount of adjusting on each panel was necessary to get the best fit. I still have my plans. Sell them to you for half price if you're interested.
https://static1.pt-content.com/images/pt/2019/05/C353A9711F0A45A594A44FB24225DBDA-1.jpg (https://s1145.photobucket.com/user/TERRYDMORGAN/media/Terrys%201969%20Camaro/16%20Trunk/C353A971-1F0A-45A5-94A4-4FB24225DBDA.jpg.html)
jamminj007
05-25-2019, 08:47 AM
I will take you up on that offer! Im local too
minendrews68
05-25-2019, 12:58 PM
PLANS! what plans... LOL
ajs1luv
06-04-2019, 05:04 AM
Where's your battery located?
terrydmorgan
06-04-2019, 07:46 PM
Between the rear seat and the front panel of the new trunk upholstery, passenger side.
Chad-1stGen
06-12-2019, 03:45 PM
Any pics of the battery mounting setup you used for that?
CarlC
06-13-2019, 01:15 PM
Need a photo Chad? Mine's on the upper trunk shelf, passenger side against the trunk divider.
dacostadesigns
08-20-2019, 03:04 AM
Alien has a Pro-Touring Forum member discount code that has been extended through the end of the year: ae04017
Chad-1stGen
08-20-2019, 03:46 PM
I think I've seen a pic of yours at some point? Each time I think about moving mine I measure it out and come up with it not fitting a full size optima battery. I'm also curious about supporting the bottom of the battery. Why type of plate is used and if any of the trunk floor is cut/modified to eliminate bumps.
