View Full Version : Connect and Cruise or build?
toofun
05-11-2019, 11:47 AM
So with so many packages out there that advertise connect and cruise what are the advantages disadvantages of going this way vs building your own. Guess what I’m asking is if you sourced all of the parts to build a motor and tranny the way you wanted tune it get the computer harness to be programmed the right way how much money would you be saving if you did it yourself compared with buying one of these packages which come with a warranty. Any thing you would be missing with one of these connect and cruise packages or is it all pretty much covered?
slimjim
05-11-2019, 04:55 PM
I chose to piece mine together rather than connect and cruise for a number of reasons. I'm still not sure if price is really a differing factor.
The connect and cruise will still require all of the front accessories ($2-3k), most likely a new oil pan, mounts etc. I also wanted to pump my LS3 up internally, so I figured by the time I'd swapped in all of the parts I wanted I was better off buying a low mile used engine and replacing everything.
TomMLS1
05-12-2019, 03:24 AM
Connect and cruise is turn key. Only thing you might need would be a different pan. Accessory drive comes with the package. Easiest way to do a swap if you don't want to hassle with rounding up parts from all over. I done a few. Everything is in the box. Even has a decent startup tune.....would purchase another without hesitation. Have to really watch these days, whole lot of scammers out there selling defective parts...
T,
toofun
05-12-2019, 04:39 AM
T,
So what swap kit or connect and cruise kits have you bought just curious which companies tend to be the most reputable and offer the best package prices.
dhutton
05-12-2019, 06:18 AM
There is only one true Connect & Cruise and it’s made by GMPP.
Speartech will also sell a turnkey package.
Don
Schwartz Performance
05-12-2019, 09:55 AM
To clarify, the Chevrolet Performance Connect and Cruise kits are not turn key.
They are a single part number made up of 4-6 part numbers.
They do not come with an accessory drive nor a starter. You can get those items as add ones from GM (granted the accessories fit your application).
We are an authorized Chevrolet Performance reseller and can help you with the additional parts (fuel, cooling, accessories, headers, mounts, pan, etc).
The thing I like most about the connect and cruise packages is the warranty, and availability.
Sometimes the trans or wiring is on back order, but often times GM has all the stuff in stock, you can have it in a few days.
The warranty may not apply if you have a 3 year build, but still a good warranty comes with it.
Plus it’s from the OEM.
Shoot me a message and I can price it out for you.
-Dale
TomMLS1
05-12-2019, 12:43 PM
Two of the 430HP LS3 with 4L70E. Two 480HP with 4L70E as well......
Pace performance has good deals....a lot of folks promise savings, so shop around...
And yes, the accessory drive and starter are extra, but they can supply them for you, hence the "turn key" term I used...obviously you need PS lines, radiator hoses etc...but that's not what this is referring to...
T,
icemanrd19
05-12-2019, 03:47 PM
I went with the ls3 480 t56 connect and cruise from pace performance. Loved the cam and extra power until I was able to get my feet back under me with all the expenses. 2 years later I pulled the cam out and went with a tsp stage 2 cam package that allowed slot more rpms and more power without sacrificing idle or drivability.
toofun
05-12-2019, 04:04 PM
Any reason any of you did not go with the T-56 versions? Always liked driving a stick but wondering if there was a soecific reason why you both go with autos?
icemanrd19
05-12-2019, 05:01 PM
Mine is the t56 magnum version
ragz
07-12-2019, 01:27 PM
Connect and Cruise 525, T56 close ratio..... 67 camaro, love it
68conv455
07-28-2019, 04:54 PM
I went with the connect and cruise - ls3/430, 4L65E
Went with it because I'm pretty good bolting things together but I'm not a mechanic.
Going the other route seemed like it had a lot more risks for me.
I recommend you assess your limitations from both a skill standpoint and your parts locating network and see if that helps you make a determination.
