View Full Version : Looking for the "right" 5 3/4" LED headlight
anguilla1980
05-04-2019, 06:28 PM
I have a GM muscle car with 5 3/4" round headlights. I want to go LED, but it seems like all the options out there are too crazy looking. I want suttle, like a stock looking headlight. No crazy LED bars or halos or junk like that. I also would like one that's DOT approved, I don't want to be that a$$hole blinding everyone at night because the light isn't directed properly in the housing.
Any suggestions? I mean hell, does anyone make a totally stock looking 5 3/4" housing that will accept a modern LED bulb (high & low, I only have 2 headlights) but has the correct reflector design for an LED? I'd also like the LED to accept my stock harness 3 prong connector, even with an adapter is fine. I'm not wanting to modify my mint original harness to install different connectors.
Thanks!
EDIT: Something just like these maybe? https://www.cjponyparts.com/headlight-kit-led-5-3-4-1969/p/HLA55/
I wonder if they will sell me just the 2 hi/low ones....
andrewb70
05-05-2019, 06:55 AM
I would like to know as well, for my 70 GTO.
79bird
05-06-2019, 05:31 AM
https://www.amazon.com/Nokya-Sealed-Headlight-Conversion-Quantity/dp/B00GUPLFMQ/ref=sr_1_fkmrnull_3?keywords=Nokya+H5006+Sealed+Be am+Headlight+Conversion+5.75%22&qid=1557149309&s=automotive&sr=1-3-fkmrnull
I used these on my suburban and they look great. Still a glass face. Plan on using them again on my Comet and Galaxie.
anguilla1980
05-06-2019, 07:33 AM
Funny you mention they are glass, never in my life would I consider ones that are plastic! It did't even occur to me that some might be plastic.
They look more modern compared to the Mustang ones I posted and they do not appear to be DOT. I'll ask on Amazon and see if the vendor responds...
raustinss
Unfortunately they arent LED thou
anguilla1980
05-06-2019, 07:35 AM
A guy in the reviews says he is using 6000k LASFIT 9007 LED bulbs with them. Do you mean the housing/reflector isn't correct for an LED?
https://www.lasfit.com/products/ls-plus-series-9007-led-headlight-bulbs
anguilla1980
05-06-2019, 07:46 AM
Those Mustang ones appear to be Autopal HL103 units:
https://www.ebay.com/itm/RARE-AUTOPAL-ROUND-5-75-HALOGEN-HEADLAMP-UNIT-146mm-H4-HL103-NO-PILOT-LIGHT/312077277013?epid=1142103809&hash=item48a9415755:g:ubIAAOSwNJRalqD3
Then just need to find an LED bulb and factory 3 pin GM connector adapter
79bird
05-06-2019, 07:51 AM
I'm using those same bulbs.
WallaceMFG
05-06-2019, 08:16 AM
Here is your solution:
https://www.dapperlighting.com/products/oe7
Up for pre-order at the moment, but looks like what you want. Just have to wait a little bit.
EDIT: Realized I was not paying attention and these are 7" units. I have to assume they will make 5.75" later. They do make 5.75" housings that can have LED bulbs in them though, and they are good quality.
anguilla1980
05-06-2019, 08:21 AM
Hopefully, they will make a 5 3/4 version. Literally, ALL of the 5 3/4 housings on their website look like stupid alien eyes, absolutely terrible lol
WallaceMFG
05-06-2019, 08:49 AM
Unfortunately, that is the price to be paid for having nice projector lights. Hard to make them look like a stock halogen housing.
anguilla1980
05-06-2019, 12:12 PM
I just ordered these:
https://www.amazon.com/dp/B00GUPLFMQ
I look forward to getting them installed, aimed, and test drive. I drive my car about 10K miles a year and about 75% of that is at dusk/night.
raustinss
05-06-2019, 04:59 PM
The problem is the reflector may or may not be designed or have the properly necessities for LED lighting , creating the proper reflection etc.
anguilla1980
05-06-2019, 05:01 PM
Correct, hence why I posted here. But since a better alternative has not been suggested, I pulled the trigger on these based on 79bird's recommendation.
From what I can tell, these specific Lasfit LED 9007 bulbs are made just for working in reflector housings and provide the proper cut-off.
Gmachine1911
05-06-2019, 06:50 PM
164106164107I might be a little late to the party but I went with the Truck-Lite 27270C (for my first gen Camaro). Not sure what they offer in a 5 3/4" but I can tell you I love mine. The look is subtle. The light is VERY bright. The install was super easy with no ballasts and they blend perfectly w/o all them busyness.
DT69Cam
05-07-2019, 04:54 AM
Check out Octane lighting. Reasonable prices too.
Camaro68+69
05-07-2019, 06:26 AM
Thanks!
I 2nd Octane Lighting, I have them on both of my Camaro's and my buddy put them on his 70 Chevelle
raustinss
05-07-2019, 01:37 PM
I've been in contact with dapper lighting , seems they are working on a 5.75 led headlight but ,are having a slight issue with finding a proper glass lens . ??? . Anyways the woman I was dealing with was informed that there is a small amount of us interested on here and the other site. She will notify me when they're available
Typhoon1015
05-07-2019, 06:42 PM
Delta has a Xenon kit with e-code cutoffs and can be upgraded to LED bulbs. I have a halo style that looks OEM when off, full glass etc. I did a ton of research from cibie stuff to china stuff to redline lumitronix etc. I am happy with the period correct look when off and a good pattern when on. Speedway motors has them and also has a video explaining the options.
anguilla1980
05-08-2019, 11:32 AM
I got them installed today. No modifications needed to the headlight buckets. The LEDs have very specific alignment notches that correspond to the housings. The wire clears the plastic housing/clamp, and the LEDs come apart to fit everything together perfectly. The LEDs end up perfectly horizontal and when turned on, the pattern is just as it should be. Props to Lasfit for making what they say, an LED that works perfectly into a 9007 housing that works with the relfector as it should.
Now, these housings still look too sci-fi for my old school tastes. I think once a company comes out with a housing/lens that looks more stock-ish from back in the day, exactly like the Dapper lighting 7", I'll throw my money at them on the spot.
anguilla1980
05-09-2019, 07:32 AM
I went to align them properly last night and noticed that for some reason, my low beam/hi beam is reversed where my dash light is concerned. In other words, when my low beams are on, the hi beam indicator on my dash is lit. When I switch to hi beams, the hi beam indicator goes off.
I'm thinking this is the wiring of the adapter that comes with the Nokya conversion housings. Any idea how to test/verify this and correct it?
EDIT: I think I found the answer: https://www.youtube.com/watch?v=hEkqssfg4Fk
Only difference is that my male 3 prong plug has red on one side, then black in the middle, and a white opposite the red. So which 2 do I switch?
anguilla1980
05-09-2019, 10:41 AM
I swapped the red and white. Working just how it should now.
andrewb70
05-09-2019, 10:45 AM
So, you got 2 housing kits and 4 bulbs? I've been vaguely following all this.
anguilla1980
05-09-2019, 10:46 AM
No, just 2. I only run the outboard hi/low beam lamps, not the inboard. I'm using the inboard lamp locations for ducting.
These things are so badass all but the latest cars off the showroom floor on the road look like they are driving by candlelight lol! I got them aimed correctly and the cut-off is perfect for other drivers to not be blinded.
andrewb70
05-09-2019, 10:48 AM
So what would be needed for the typical 4 light setup?
anguilla1980
05-09-2019, 10:49 AM
2 housing kits and 2 bulb kits.
The LEDs can do hi/low so your inboards just would never go to high beam due to the factory wiring but all will work just fine.
