View Full Version : KPI for 02 wrx front spindle
Ddkeeler
04-26-2019, 07:36 PM
As the title states I am trying to determine the king pin inclination angle of the wrx front spindle. What I am coming up with is a 13 degree angle which seems pretty high. Does anyone have any experience with the kpi angles on any McPherson strut type suspension?
MonzaRacer
05-26-2019, 07:21 PM
2002 Subaru Impreza WRX Sedan F4-2.0L DOHC Turbo
Vehicle » Steering and Suspension » Alignment » Specifications
Front
Model Sedan Wagon Outback
Turbo Non-Turbo Turbo Non-Turbo
Camber
Note: Tolerance : +/- 0 deg. 45' -0 deg 25' -0 deg 15' -0 deg 20' -0 deg 10' -0 deg 05'
Caster
Note: common difference : +/- 0 deg 45' 3 deg 25'
Toe-in 0 +/-3 mm Each toe angle : +/- 0 deg 07' 30"
Kingpin angle
Note: Tolerance : +/- 0 deg 45' 14 deg 35' 14 deg 20' 13 deg 45' 13 deg 30' 13 deg 20'
Wheel arch height
Note: Tolerance : +/- 12 mm 396 mm 406 mm 387 mm 397 mm 402 mm
Rear
Item Sedan Wagon Outback
Camber
Note: Tolerance : +/- 0 deg 30' -1 deg 30' -1 deg 25' -1 deg 20' -1 deg 15' -1 deg 10'
Toe-in -1 +/-2 mm Each toe-in angle : +/- 0 deg 07' 30"
Wheel arch height
Note: Tolerance : +/- 12 mm 376 mm 381 mm 376 mm 381 mm 386 mm
Thrust angle 0 deg +/- 20'
Diameter of stabilizer 20 mm 13 mm 17 mm 13 mm
