View Full Version : Cut/modify sill to fit aftermarket bucket seats in’67 camaro
Bullrider
04-20-2019, 09:28 PM
I bought E46 BMW Vader bucket seats for my ‘67 camaro project. They are just a touch to wide and not centered on the steering column (too far inward). I would like to cut and trim the sill about 1-1.5”. Has anyone done this before? It will allow for a more aligned set-up. https://www.pro-touring.com/blob:https://www.pro-touring.com/ddf234c2-ce40-4341-b849-aede4fb5a8dd
cdrod
04-21-2019, 07:06 AM
I had similar issues installing a pair of E46 M3 convertible seats into an A-body, Olds convertible. In my case, not only were the seats off-center but they were also too low. I fabricated some seat support rails from 1/8" steel plate that lifted the seats up about 1-1/2" and shifted them outboard almost 2". The A-body has a full frame so I couldn't notch the sill much without getting into the frame rail. You may not have the same issues with F-body and sub-frame connections. Here's some pics of the supports I made:
163593
163594
163595
slimjim
04-21-2019, 03:32 PM
Here's what I did to fit 5th gen seats, reinforced it as it's structural.
https://static1.pt-content.com/images/pt/2019/04/FMhGhRK-1.jpg
Bullrider
04-22-2019, 05:58 PM
Thanks for the photo. This is exactly what I had in mine. How thick is your steel where you did the modification? 1/8”??
slimjim
04-23-2019, 12:04 AM
we used 1/8" on the flat piece and 1/4" for the side reinforcement
Bullrider
04-23-2019, 03:44 AM
It looks like not only did you cut into the sill, but you removed the top piece of metal of the seat pan, allowing you to mount the seat lower in the car for more headroom. Is this correct? I may need to do the same so we are not looking out at the top of the windshield when driving.
slimjim
04-23-2019, 04:08 PM
That is correct yes, we removed the original seat pan altogether, reinforced the floor at all seat mounting locations(important), and made new mounting locations, I'm 6'1" and have plenty of room in there now.
I don't have many pictures of this modification and I'm currently away from my car, but on this picture you can just barely see what we did on the 2 inside mounting locations.
https://static1.pt-content.com/images/pt/2019/04/HUdA1kH-1.jpg
Bullrider
04-23-2019, 04:25 PM
Thank you very much. This is exactly what I needed.
robert worl
04-27-2019, 09:54 AM
James, or any one else who has installed 5th Gen Camaro seats in their car I’m curious how difficult the wiring is for the power seats. And also for heated and vented seats.
I have been looking at Mustang seats as I understand they not only fit comfortably in the first gen Camaro without any still or floor pan modifications, and the wiring is very simple for the power controls as it’s just a hot and a ground connection. I’m not sure about the wiring for the heat and ventilation on the mustang seats.
I know the 5th gen Camaro seats are a bit more work to fit properly but I’m at that stage of my build that this is an option to consider.
Any feed back is greatly appreciated.
thanks, Robert
