View Full Version : stepping out of my zone, whats the differnece between manual and boost assit brakes?
qnitro
04-16-2019, 07:03 PM
Hey guys, I bought this car below, and its set up with a Manual brakes, I want to add a Hydra-boost as the subframe/gage brace gets in the way of a typical Booster..But than I though about it, what the difference between all the various set ups.. and does any recommend a Hydra-boost?
https://lateral-g.net/forums/showthread.php4?t=30588
ajaccola
04-16-2019, 08:44 PM
Personally I am a manual brakes fan. When set up correctly they provide the same stopping power as assisted brakes and keep the engine bay looking clean. I have heard that hydra-boost can cause problems when turning and heavy on the brakes. I don't have any experience with that system though, looked into it once but didn't want to have to change my reservoir on my serpentine setup and have a mess of ugly lines.
qnitro
04-17-2019, 10:37 AM
Hmmmm I might have to rethink the manual brake thing
jetmech442
04-18-2019, 12:55 PM
I chose not to use the hydroboost that came on the LQ9 because it requires the steering pump to maintain a volume flow that decreases sensitivity in the steering, and steering feel is what I've been chasing now for a while(by reducing flow).
This week I am installing a 1 1/4 Mc with a C6 dual 9'' booster. I am doing this because my current pedal travel with the 1/8th is too much for me to effectively(read: at all) heal toe on track. The brake feel is also vaugue-ish and I can lock em up with just a little more effort than than my ankle(yes I'm big boned).
So, while I don't know if it's what I'm trying to get(should know next week), I'm hoping that I am trading more leg force for less travel. For reference, I am using D52 calipers up front and D154 calipers in back with Wilwood BP-20 pads.
There is a staggering amount of info this thread "Brake sizing and selection tutorial featuring Ron Sutton and Tobin of KORE3". The maths I learned from that thread say I should be heading in the right direction, we shall see. Hope this helps some.
c4racer2
04-23-2019, 09:57 PM
Not really. If properly designed you won’t need more leg force than a similar brake package with booster. What you will have is more pedal travel. Assuming you use a manual friendly ratio in the 6.x range
jlcustomz
04-26-2019, 02:31 PM
My 83 el camino came factory with hydroboost & had large gm worktrucks with that setup before. They can give the feel of stronger clamping power & are great for a low vacuum engine, such as a diesel or big cam old school engine or even late model big cam setup.
The factory gm units definitely don't have pretty plumbing. If you have proper return flow, it will minimize the issue of using turning & hard brakes at same time.
For a high performance street car, I'd do hydroboost again. A mostly track car, doubt anyone would.
RobNoLimit
04-30-2019, 05:50 AM
Look into ABS Brake Co. 's "Electric Hydroboost set up.
TheJDMan
05-09-2019, 03:13 PM
KISS! A manual brake system is as simple as you can get and when properly designed it will be every bit as effective as any boosted brake system. A manual brake system is also more reliable simply because there are fewer parts to fail.
jlwdvm
05-10-2019, 05:13 AM
Effective....yes, but with a much different feel, as I am finding out!
