View Full Version : Baer Brakes question
KnightmareZ
04-16-2019, 05:43 PM
Can you run the T4 caliper on the 13" SS4+ rotor?
Or stated differently, does Baer make a bracket to make this happen?
See, I'd like to run the T4 on all 4 corners but also need the parking brakes.
Thoughts?
andrewb70
04-17-2019, 06:31 AM
Have you contacted Baer?
Josh@Ridetech
04-17-2019, 09:10 AM
What he said ^. I'd give Baer a call. All of their tech guys are fantastic.
KnightmareZ
04-17-2019, 10:38 AM
Just called. They only offer the T4 for the front.
NoSleeperII
04-20-2019, 02:45 AM
Knightmare. I’m going through the same right now on NoSleeper68. They only make the T4 caliper with one piston bore size as I’m sure this is what Baer told you. I wanted to run a 13” 2 piece rotor up front as well and can’t do that either because of the caliper dimensions they bracket would be spaced out to far and push the caliper higher on the rotor. I ended up going with the T4 w/one piece 13” up front and S4 caliper with 13” 2 piece out back with parking brake. This is all on power brakes.
If my daughters brakes outperform my 6s manuals, I’m going to be pissed.!!.!.
KnightmareZ
04-21-2019, 01:07 PM
I think I will go with the S4 12" so everything looks the same. I wonder how the T4 rotor hat would look painted to match the S4+ 13" 2 piece?
