View Full Version : Changing Studs on Camaro Pedal Assembly
willt
03-31-2019, 08:37 PM
The studs on my stock 68 Camaro pedal assembly (that mount through the firewall) are too short for a Wilwood MC with Combination Proportioning Valve. Note; I am not running a brake booster. Is it possible to press the studs out and replace them? If you have done this any tips would be helpful.
Thanks in advance, Will
Schwartz Performance
04-01-2019, 06:24 PM
Gotta cut them off.
-Dale
willt
04-01-2019, 07:44 PM
Gotta cut them off.
-Dale
What would you suggest after I cut them off?
04-02-2019, 10:09 AM
Weld a longer bolt to the back side after you cut the old one off.
