View Full Version : 2016 -2018 electric ebrake in a first gen
nickburns31
03-28-2019, 11:54 AM
Hey fellow enthusiasts - Has anyone tried using the 6th gen console with the electric ebrake? I am thinking it’s just servos and still uses cables going back to the brakes? Thanks in advance... I have exhausted google and I found the actuator for about 120.00
joeko23
03-29-2019, 09:11 AM
In my build I used this kit, it’s cheap. I mounted it in the trunk floor under the package tray. The question is if you can use the button on the 6th gen console to use it. I have not played with that yet, but I don’t see why not. I believe it’s a simple polarity switch. There’s a programmable box you can also use I think it’s like $150 that you can program any switch to do anything you want. It’s posted in the electrical section I forgot the name of it.
https://www.ebay.com/itm/Push-Button-Electrical-Emergency-Brake-Kit-with-Cables-parking-ebrake-gasser-ez/123134844773?hash=item1cab689f65:g:9pgAAOSwhEla-vd4
1985olds
03-30-2019, 02:31 PM
I was looking at the c7 electric parking brake too and was unable to find anything or any schematics. Hopefully you get and answer.
nickburns31
03-30-2019, 05:28 PM
Thank you for the follow up! Does the unit beep and is it slow to respond like the ones for sale on summit ??
joeko23
03-30-2019, 07:22 PM
I hooked up the actuater to a motorcycle 12v battery and it worked pretty quickly. No beeps.
nickburns31
03-30-2019, 07:42 PM
Perfect !!! The E stoop one looks and sounds horrendous
joeko23
03-31-2019, 10:15 AM
I never heard the estop one but the kit I have the actuater is inside that metal box which quiets it down a lot plus I figured I can put some sound deadening inside to further quiet it.
