View Full Version : Shock Relocation for Leaf Springs and Mini tub - 1969 Camaro
ubac
03-16-2019, 03:21 PM
I'm in the process of installing leaf springs in my 1969 Camaro that has mini tubs. I purchased the car as a project and didn't realize that the original shock mounts were cut out in order to install the tubs. My question is can somebody recommend a shock relocation kit that will work for this setup? I'm looking for something as close as possible to bolt on and doesn't require welding.
Psydwaze
03-18-2019, 12:01 PM
This option requires welding, but installation is very simple.
http://www.cachassisworks.com/p-1494-varishock-coil-over-shocks-and-mounts-package.aspx
John McIntire
03-18-2019, 04:52 PM
My buddy just used this on his 68 he mini tubbed.
https://smithracecraft.com/product-categories/rear-suspension/shock-relocation-kit
pittpens24
03-19-2019, 02:34 AM
Why not go with coil overs?
ubac
03-20-2019, 05:33 PM
Because I already had that leaf springs before I realized the shock issue.
I am probably going with the SmithCraft. Thanks guys!
blainemeyer
03-26-2019, 04:12 PM
I first tried the POL relocation kit, https://www.performanceonline.com/1967-69-Chevy-Camaro-Pontiac-Firebird-Shock-Relocation-Kit-Rear/, as it looked like a complete bolt in. I couldn't get it to fit even with help from their tech support. I went with the smithracecraft even though you have to weld it in https://smithracecraft.com/product-c...relocation-kit
Bad Bowtie
03-27-2019, 12:44 AM
Smith Racecraft for me too... link fixed here https://smithracecraft.com/product-categories/rear-suspension/shock-relocation-kit
BB
jorgezee1
05-14-2019, 04:45 PM
I have this BRP kit
https://www.pro-touring.com/threads/131158-1st-Gen-Camaro-BRP-Rear-Shock-Inboard-Relocation-Kit?highlight=brp+jorgezee1
OldTimer
05-26-2019, 09:04 AM
I'm curious about how you guys that converted from staggered to regular shock setups like the end result. Any issues with wheel hop or handling in corners? What leaf springs, shocks are you using and do you have subframe connectors or rear sway bars or a panhard bar installed?
I've got a Right Stuff rear disc setup I hope to install soon when I get my new rear axle setup. Would like to mount the brakes so the calipers are in the same spot and the bleeders are in a good position.
Pictures would be awesome.-Mike
ryeguy2006a
12-09-2021, 09:20 AM
I know it's an old thread, but I am going down this road too and had the same question. Any issues with wheel hop?
