View Full Version : 1955 Chevy 6.0 all wheel drive
camaro jeff
03-13-2019, 04:49 PM
Having finished my 6.0 GTO swap into a 69 Camaro, I started on a new project a Chevy Trailblazer chassis under a 55 Chevy pickup, swap going pretty good with everything fitting with just some modifications. The issue I am now having is that I have disconnected the power door locks, power windows, etc. , things I won’t use in the swap but I didn’t think about the alarm/ security in Chevy ,so now it is in lockout alarm and will not start. I have talked to several ecm companies and they been of no help because they don’t do bcm’s. Any input, suggestions, and or experience with this would really help me. I could get it to start by rewiring, but there are other things that I would want to work that are controlled by the bcm.
Thanks Jeff
Jaymzz
03-14-2019, 03:28 AM
You need to tune the vats security out of it. Not sure if it can be done with hp tuners but you can also have a tuner disable it also.
camaro jeff
03-14-2019, 04:07 AM
I talked to HP tuners out of Chicago, said they only tune the ecm not the bcm , so still looking for answers.Thanks for your response.
Jeff
dhutton
03-14-2019, 04:43 AM
I think one way to go would be to spoof the BCM by attaching loads that emulate what is normally connected to the unused interfaces. At least that is the way I would proceed initially. It might be as simple as adding pull-up resistors etc.
Don
Interceptor5588
03-14-2019, 04:52 AM
I've been thinking of doing something like this. What other pitfalls have you had to overcome? Any build pics?
camaro jeff
03-14-2019, 05:51 AM
That was my initial thoughts to, just don’t know where to start as far as resistors. Was thinking about connecting door locks as though they are open tricking bcm into thinking doors are unlocked but don’t know if there is a signal/ pulse involved are just a negative trigger that’s why I was hoping someone has run into this before.
Jeff
camaro jeff
03-14-2019, 05:59 AM
I used firewall and floorpan out of the trailblazer, no big pitfalls, trailblazer is within an inch of 55 wheelbase. Had to move body mounts and give up some bed height. Don’t have a ton of photos but would help you with issues once you get started. Biggest issue I have is this GM passcode cause I want to use as much of trailblazer as I can including steering wheel, console, dash, instrumentation,hvac, etc. and it all runs through bcm. If I can get this resolved others can make this same mod .
Thanks Jeff
dhutton
03-14-2019, 07:45 AM
Jeff
You could just shotgun it and try 4.7k pull-up resistors on the unused lines. Unlikely anything would be damaged. I’m guessing you are a trailblazer on this one. :lmao:
There is a member here, blitzer454, who might be a good person to ping. He knows a lot about these systems.
Don
