View Full Version : OEM Underhood fuse box
vette427-sbc
03-01-2019, 04:20 PM
Im looking for an OEM underhood fuse/relay box to put... under my hood... I looked at the Eaton/Bussman stuff, but they do not offer any "weatherproof" power distribution modules that use mini relays. I need at least 4 mini relays and 2 micro relays with at least 8 fuse locations. (2 electric fans, quad headlights, horn, and a few other low-er current things) I have started to look at BMW and Mercedes but its kind of difficult to narrow down my results with such a broad search term. Size is also a major concern, and many modern underhood boxes house 30+ fuses. Im trying to think of smaller, no-frills cars like a BMW Z3 that I can search under.
Anyone have a daily driver where they popped the hood and think "wow thats a nice power distribution box to retrofit into a hotrod!" Or is that just me?
eville
03-01-2019, 04:40 PM
According to this:
https://www.waytekwire.com/datasheet/LiveWire_46055.pdf
these are water tight.
https://www.waytekwire.com/item/46055/EATON-s-Bussmann-Series-31S-000-0-ssVEC/
raustinss
03-01-2019, 05:54 PM
Oh god .. I wanna think there was a mid 90s early 2000 gm , maybe it was a Buick of some sorts that had one . Let me do some digging I'm sure I can come across it again
vette427-sbc
03-01-2019, 06:01 PM
According to this:
I love those (and waytek) but I have concerns about micro relays handling the current of my electric fans long term.
I remember someone posting a GM box a while ago too but couldn’t find it. If you do I would really appreciate it!
GoodysGotaCuda
03-01-2019, 06:53 PM
I wouldn't have any concerns with putting this under the hood, it has available connector seals and a sealed lid. 5,300 miles and my Contour fans have not given me any problem. I one run relay on low speed and two relays in parallel for high speed [not shown].
It's a bussmann. I'd much prefer something like this rather than trying to piece together and modify an OEM box.
161949.
vette427-sbc
03-01-2019, 08:29 PM
believe me... if bussman made a panel with mini relays I’d already have it on my car! With two separate fans, I like to run them on two circuits so if one fails I still have one. That would equate to running 4 micro relays for only two fans, which doesn’t make sense to me. I re-pin and modify OEM connectors and fuse boxes almost every day so that doesn’t bother me. The OEM stuff is **usually** over built and being that this will be in an extreme duty environment, I’d like to engineer this to be as reliable as possible
eville
03-01-2019, 08:54 PM
Run a pwm for the fans.
PonchoJohn
03-04-2019, 12:07 PM
I bought a couple of these...
https://www.online-led-store.com/ip65-waterproof-6-slot-atcato-fuse-6-slot-5-pin-relay-box-accepspwr0312
They use standard Bosch-style relays, but I grabbed some 50 amp and some 40 amp versions to handle the current- I haven't wired them yet, so I can't say how good/bad they are, at this time.
cdrod
03-04-2019, 03:28 PM
Waytek sells this Bussman fuse box that holds 5 micro relays and 10 fuses. PN15303 2-2-4 has a common buss bar to feed power to the fuses. The max current is 80amp. You have to crimp the terminations and stab them from the back side. Everything has a watertight seal.
https://www.waytekwire.com/item/46343/EATON-s-Bussmann-15305-2-2-4-Mini-Fuse-Panel-/
Rodney
vette427-sbc
03-04-2019, 06:01 PM
Thats pretty much exactly what Im looking for... Hows the quality of that fuse box look? Im mainly concerned with the terminal ports. Most of the cheap stuff has sloppy castings there and the terminals dont always lock in properly. It says Nylon 66 so I assume its not glass fiber reinforced? For 20$ its worth a gamble I guess!
Ive got some Tyco and Hella relays from waytek that have held up well for my fans and push start system. I think they are rated for 40A. Ill likely use them here as well.
Richard454
03-04-2019, 08:39 PM
These are a favorite of mine- not waterproof- but for my fans I put them in a voltage regulator box- so it looks "stock" and its waterproof.
Used them all over my car- even to replace my fusebox.
https://www.autoelectricsupplies.co.uk/product/701/category/63
I've seen that box- I just don't know about the quality...was even thinking about using the modular ones and putting them in a waterproof box....
If you get one- do report back on the quality.
162077
Voltage Regulator-AKA relays for fans!!!
162078
162079
PonchoJohn
03-22-2019, 09:00 AM
Like I said, I haven't wired it up yet, so I can't comment too much on the quality of the wiring interlocks, but I will say this:
I had previously ordered some HD waterproof Bosch-style relays from Online LED Store, and the wiring and connections were all top rate. I noticed that the waterproofing seal that goes on the bottom of the relay panel looked remarkably similar to my OLS waterproof relays, so I compared them- YUP! Same seal! This will help me since I already have 12 ga pigtails from the waterproof relays- I'm just gonna disconnect the connectors/wiring/seals from the waterproof relays and install them in the fuse box.
The fuse box has a silicone perimeter seal that seats in the upper housing cover, a molded waterproof seal for the wires, and individual seals (kind of like a Delphi or Deutch connector) for the fuse wire leads. The box seems likes it's a well made plastic, but I won't know for sure until it has done some time in the engine bay.
I see a lot of offroad guys using them (that's where I initially heard about them), and their stuff is pretty hot/muddy/wet, so I'm hoping that's a really good sign for me! LOL
andrewb70
03-24-2019, 08:48 AM
The Bussmann boxes are excellent. I have used them in the past. They use Metripack 280 series terminals that are rated for 30amps. I have also pulled delphi parts from the junkyard and purchased new terminals from Mouser to complete whatever I need. Delphi (or whatever they are called now) also sells sealed mini relay bases that can be used with "skirted" relays. Waytek has them. They use Metripack 630 series terminals.
vette427-sbc
03-24-2019, 01:00 PM
I caved and bought the Bussman ssVEC fuse block/ power distribution module. Picker makes relays that are supposed to have a higher tolerance to inrush current spikes which is what sparked this whole search. Ill just keep an eye on the fan circuits and cross my fingers.
andrewb70
03-24-2019, 01:04 PM
PWM fan control would eliminate concerns for inrush current spikes.
vette427-sbc
03-24-2019, 01:50 PM
V2.0 will have PWM and the CAN communicating ssVEC power distribution modules... For now, Im going to deal with it as is. Ive come to realization that this is an OK corner to cut for now so I can get moving with the rest of the build.
vette427-sbc
03-29-2019, 05:24 AM
The Bussmann box showed up today, specifically the ssVEC 31S-000-0. Its a really nice piece... BUT the 85 coil is common among ALL 8 RELAYS!!! WTF?? I have negative and positive relay triggers, and many of them are not common to the rest of the relays. I already took the box apart and can see why its like this (cost of mfg)... not modifiable either. I would have paid extra money if they offered a box individual relay coil terminals. At least make the schematic easy to find online... Its not included with the unit
Under the documentation tab -> drawings -> PDF
https://www.eaton.com/Eaton/ProductsServices/Electrical/ProductsandServices/Transportationsolutions/PowerDistribution/VehicleElectricalCenters/SevereServiceVEC-ssVEC/index.htm
/Rant over
andrewb70
03-29-2019, 05:37 AM
Chris,
There are several versions of that box, so you have to look carefully at exactly which is being ordered. I like the one where the main power feed is busses, that way I can choose how to trigger the relays.
vette427-sbc
03-29-2019, 06:14 AM
Chris,
That was the first thing I checked... All versions have the common 85...
andrewb70
03-29-2019, 06:16 AM
Pretty sure there is a version as I described. It might be the one you have and you install the relay upside down.
CSG
03-29-2019, 06:44 AM
That is a nice box but looks like you would need two to do what you are wanting to do.
