View Full Version : Calling all spectre performance users!
Trackside-Suzy
02-27-2019, 01:41 PM
I'm working on something and need Spectre Performance (intake, etc) customers. You will not be put on a mailing list but you may get your car showcased on social media channels and there may be an opportunity for some swag.
Any type of car, any phase of build.
Thanks!
KacyZ28
02-28-2019, 06:28 AM
Thanks!
What are you needing and all products? I only have their air filter.
rickpaw
02-28-2019, 11:36 AM
I use their filter, couplers, intake tubing to piece together my intake.
AU Doc
02-28-2019, 01:51 PM
I used their LS Swap intake tube/filter kit for my camaro.
70rsss396
02-28-2019, 02:04 PM
Not finished with my build yet but I will run this air cleaner. 161917161919
spacepirate
02-28-2019, 02:37 PM
I run your air intake setup for my 68 Camaro, LS3.
Trackside-Suzy
02-28-2019, 07:14 PM
Kacy, any products are great. Can I have your last name?
Trackside-Suzy
02-28-2019, 07:15 PM
Can you DM me your first and last name?
Gmachine1911
02-28-2019, 07:31 PM
I'm running their air filter and tube coupling...
astroracer
03-01-2019, 07:48 AM
I am using a complete kit on my '95 Sierra.
https://static1.pt-content.com/images/pt/2019/03/2vhiedWnx9EDKg-1.jpg
https://static1.pt-content.com/images/pt/2019/03/2vhiZeqrx9EDKg-1.jpg
My '88 Astro is under development. :)
https://static1.pt-content.com/images/pt/2013/12/ry3D400-26.jpg
https://static1.pt-content.com/images/pt/2013/12/ry3D400-27.jpg
Mark
1972Mach1
03-01-2019, 09:15 AM
I run a Spectre air cleaner assembly on my Mach 1 and have a few little knick knacks like plug wire holders on my Riviera's engine.....
nokones
03-02-2019, 05:16 AM
My 89 C4 with a Lingenfelter SBC427
161950
jlcustomz
03-02-2019, 10:40 AM
I used a spectre 4" cone filter inside my custom made air scoop.
161966161969
badazz81z28
03-02-2019, 12:27 PM
I’m using the 70-81 Camaro Spectre Kit
TheJDMan
03-02-2019, 09:10 PM
I'm running the Spectre Cowl Induction air cleaner on Dust Off. Also running coilover springs from Suspension Geek.
161990
Later-A-body
03-09-2019, 11:56 AM
I am using the Spectre air filter and coupler on my LS7 swap. I am located in southern California.
162244162245
Rod
03-09-2019, 04:09 PM
Can I join in? I have some Spectre parts also.... air cleaner, spoiler, door panels, door handles, fuel rail for Holley, return springs and brackets, Carburetor spacer, thermostat housing, radiator overflow, exhaust manifold gaskets, differential cover ..... I know there is more .....
162264
