View Full Version : Front Drive assembly 2015 LSA GM
nickburns
02-23-2019, 11:13 AM
Front Drive assembly with A/C compressor and 2 wire Alternator for sale. This is off of a crate motor from GM and I can’t use the drive assembly for my Detroit Speed subframe / 68 Camaro. 950.00 plus shipping. Assembly is still on motor as shown in pictures - I took the one tensioner wheel off to get to one of the bolts to lift the motor out of the crate . Also attached is the two kits from SD that show the GM prices.
161771161772161773161774
Shotaro
03-03-2019, 06:38 AM
161992 My motor is broken here. I would like to swap lsa to 70 camaro. Can I use this part?
nickburns31
03-03-2019, 12:12 PM
I will follow up as soon as I get home and check my LSA. The assembly is still mounted and I’ll check
nickburns31
03-03-2019, 12:20 PM
162009
You can see from my picture that the part of the block that was hit on yours is not used. I would check the forums to see if this would fit with your subframe.
Shotaro
03-04-2019, 05:25 AM
162009
Thank you but I am not an original frame. I also have a rack and pinion.162023
nickburns
03-04-2019, 06:11 AM
You would just have to do some research to see if this would fit -
Shotaro
03-07-2019, 05:26 AM
It seems not to be installed;(
162189
