View Full Version : Tuff Stuff booster 2229 install
Cunning69
02-20-2019, 07:54 AM
I am sure a lot of you have run into the same situation and I hope someone has a solution.
I will be installing the 2229 booster with the DSE brackets on my 69 camaro. The booster has a long rubber boot that will need to extend through the firewall by an inch or two. I have seen posts where folks have had to enlarge the opening in the firewall so it will fit.
Here is my issue, the rubber boot will not seal against the firewall, just pass through. How do you make this opening weather proof? I do not want water or engine smells getting into the cabin.
Thanks for your help
a67
02-21-2019, 07:24 AM
There is a seal plate and seal to go with the angle brackets. See this install instructions for details:
https://www.detroitspeed.com/img/product/description/Braking/Detroit%20Speed%20Brake%20Booster,%20Master%20Cyli nder%20Kit.pdf
Note that the %20 in the URL are spaces, may need to edit the above link for it to work:
https://www.detroitspeed.com/img/product/description/Braking/Detroit Speed Brake Booster, Master Cylinder Kit.pdf
Bob.
eville
02-21-2019, 09:46 AM
Bob.
Weird that they sell the brackets but not the seal or the seal plate...
Cunning69
02-22-2019, 07:33 AM
Thanks for the help, I contacted DSE and they do sell them separately. You just have to call and tell them what you are looking for. About $30 for both pieces, plate and rubber boot/seal.
eville
02-22-2019, 09:30 AM
Awesome. Thanks.
JuStBlAzIN
04-10-2022, 06:01 PM
do you have any pictures on the plate ?
slazisme
04-15-2022, 08:33 AM
198989
streetk14
04-19-2022, 06:02 AM
So it looks like the parts DSE sells still work with the Tuff Stuff booster? Any info on compatible master cylinders?
