View Full Version : Drive Junky now shipping L83 L83 truck engine accessory drive systems
zschary
02-18-2019, 12:34 PM
We are shipping our answer for the L83 L86 truck (silverado etc 2014 up) accessory drive systems
Designed to fit without modification early GM frames, while adding power steering and AC for aftermarket AC kits
Introducing our new GEN 5 "truck engine" L83 and L86 accessory drive system. Brand new design. This is an economical answer for those guys pulling these engines out of late model Silverado's, and other Chevy trucks. Even though these are truck engines they are very similar in architecture to the LT1 engine found in high performance newer GM cars. These are aluminum engines that have direct injection, VVT and variable displacement, as their LT counterparts do, for an economical high performance answer for rodders looking for a cost effective solution.
Drive Junky has engineered this new design to allow these high tech, high performance engines to fit into older muscle car and truck frames.
Includes Type 2 power steering pump setup necessary for older vehicles. (modern gm engines use electric power steering)
-Automatic belt tensioner
-All stainless steel high strength hardware.
-Sanden brand (not knockoff peanut style) ac compressor with custom one piece manifold to adapt to standard hose O ring fittings and all aftermarket AC systems, and billet AC pump cover.
-Aluminum power steering type 2 gm remote style pump for external mounted Power Steering reservoir. (customer supplied)
-Machined out of solid billet 6061 aircraft aluminum in large pieces. This is a big difference here, we utilize heavier stock and machine away more material than our competition to minimize additional parts (spacers) to fit the parts better. This is much more expensive and labor intensive than the "plate and spacer" technology you see all over the industry.
-Accessories are easily removed for engine service, much thought has gone into this, we all work on our engines from time to time.
Powermaster OEM style black 180 amp alternator (high quality finish only available here)
this system will delete the factory vacuum pump
And of course this kit is entirely built and machined by us here in the USA, and runs to quality usa accessories.
www.drivejunky.com
