View Full Version : DeWild 69 Camaro pro-tour project. Gen V LT5, Sequential 6 speed, Carbon brakes
RDeWild
02-11-2019, 02:20 PM
Hey Guys, Bought this 69 Camaro Project a couple years ago and now Im getting started on it. Hopefully will be done sometime this year.
Bought this project and boxes and boxes of parts. Have made some good progress the last couple of months.
Entire build will be done in my shop here in Denver, CO
Drivetrain:
GEN V LT5 supercharged
Billet sequential 6 Speed transmission
RPS triple carbon clutch
Suspension:
Speedtech Extreme front and rear
Brembo Carbon Brakes 15.5"
Cant wait to start pounding the gears!!!
161371
161372
RDeWild
02-11-2019, 02:25 PM
Started off with a pretty good body and boxes of new parts came with the deal..161373
161374161377161378
andrewb70
02-11-2019, 02:27 PM
Sounds like a very cool project. What transmission do you plan to use?
RDeWild
02-11-2019, 02:35 PM
Started the mini tub and new firewall last month...161379161380161381161382161383161384161385
RDeWild
02-11-2019, 02:39 PM
Hey Andrew, Im going with this RTS sequential 6 speed.
161386
161387
RDeWild
02-11-2019, 02:46 PM
Some more of the parts Ive got so far..
161388161389161390161391161392
ssmike
02-11-2019, 06:44 PM
Good lord! That's some TRANS eye candy....Very cool.
RDeWild
02-11-2019, 07:52 PM
Thanks...I’m not going to want to bolt it in the car.... haha
Put in the speed tech extreme tunnel to clear the trans, also found a MCI interior kit on the forums. Showed up a couple days ago. Really like it so far. Was worried the console wouldn’t clear my trans tunnel but it went in there good.
161400161401161402161403
RDeWild
02-11-2019, 08:07 PM
Some of the fab work so far. Still haven’t decided on what color to paint this car. Have to decide kind of soon, getting ready to smooth out the underside
Speed tech rear crossmember tig welded in. Tilton clutch master mocked up, and master cylinder out of a 14 z28. Trans tunnel fab. Transmission with shifter, no h pattern on this one!
161407161408161409[ATTACH=CONFIG]161410161411161412
andrewb70
02-11-2019, 08:12 PM
Great looking trans, and for what it is, the price seems quite reasonable!
I was looking at their website, but could not find the ratio table.
What gear ratios did you get?
RDeWild
02-11-2019, 08:16 PM
Some more parts here
Triple carbon clutch and bell housing
161413
161414
161415
RDeWild
02-11-2019, 08:25 PM
Hey Andrew, they have pretty much any ratio you’d need. I have the chart somewhere in my email. I’ll post it up on here when I find it.
I was looking at a lot of different sequential transmissions and this one holds a lot of power, it also helped they had $3000 off for the first 25 customers who bought them and was made in the USA. So I thought it was a killer deal.
I specd mine with 2 overdrives
Rod
dhutton
02-12-2019, 04:45 AM
Glad to see my MCI interior found a good home. Will be following this one.
Don
DT69Cam
02-12-2019, 06:23 AM
Outstanding!
Schwartz Performance
02-12-2019, 07:05 AM
Wow that trans is beautiful.. ! Very cool build.
Should've used a full floater rear end in my opinion :)
-Dale
76TA
02-12-2019, 08:25 AM
Yeah. $15,500 according to their website.
RDeWild
02-12-2019, 10:58 AM
I agree a floater would be cool. I got a great deal from Speedtech on the suspension parts as a package but it’s never too late to change to rear floater.. haha
You know how it is with these cars it always starts out with some sort of a budget then gets blown way out of proportion with cool stuff. I think at this point I don’t even want to know how much I’m going to have in this one.. haha
RDeWild
02-12-2019, 11:03 AM
Got mine a couple months ago for 12,500 shipped with gear indicator. I think I was one of the last guys to get $3000 off. Add that with triple carbon clutch, bell, LT5... doesn’t take long to get a ton tied up quick!!
RDeWild
02-12-2019, 11:12 AM
Don
Hey Don, thanks for the deal on the interior!!!
Anybody know of a really good power window kit for the Camaro’s?
Starting to look at wheels, leaning towards Forgeline. Any dealers on here?
D-Man
02-12-2019, 11:38 AM
Exciting project. Nice to see a local on here as well.
RDeWild
02-12-2019, 11:48 AM
Hey Andrew, I screen shot the ratio charts. Here are the ratios. if you cant see it good enough PM me your email and ill send it to you
161428
161429
RDeWild
02-12-2019, 11:54 AM
D-Man, My shop is in Henderson you could drop by and check out some of the projects. Also have chassis and engine dynos if any of your buddies need dyno time.
TQuillen
02-12-2019, 12:43 PM
Is that a P/S car in the background?
Travis
RDeWild
02-12-2019, 06:14 PM
Travis
Hey Travis, Yes it is. NHRA PRO STOCK chassis
161446
161447
RDeWild
02-12-2019, 06:19 PM
Makin small steps, almost time to start smoothing out the underside. Trans tunnel in.
161448
161449
161450
dhutton
02-12-2019, 06:37 PM
Nu-Relics are the best power windows. They have door or console switch options. Matt’s Classic Bowties can set you up. Same with Forgeline wheels.
Don
02-12-2019, 07:43 PM
I agree with Don, Nu Relics works the best.
We are a dealer for both companies, I’d be happy to help you out.
-Dale
CarlC
02-14-2019, 07:46 AM
Great project! The firewall plate is a slick piece.
When planning the fuel system be aware that the GM fueling requirements in their instructions may be incorrect. The latest specifications of the LT1, LT4, and LT5 all have the same 45gph flowrate requirement. That's not enough for LT5.
The LT4 in the Gen6 and CTS-V uses the same pumping section as the Gen5 ZL1 module. At 650 rated horsepower, the engine is evenly matched with the GM Performance recommended Gen5 ZL1 pump that makes 60gal/hr at 65psi. The LT5 is another 100hp on top of that, so more pump will be needed.
Early versions of the LSA fueling instructions were incorrect as well, so it's not unprecedented that GM Performance has some difficulty specifying their aftermarket conversion requirements.
RDeWild
02-14-2019, 12:23 PM
Thanks for the heads up on the fuel system stuff. Definitely don’t want to buy parts twice!
in the LT5 paperwork it said to run it at 75psi, I’ll have to look and see if there was any reccomended pump gph.
Finally got some front drive parts yesterday, ECMs are still not ready yet. I’ve had the engine for about 3 months hopefully GM will have the stand alone sometime soon.
have to make some power steering brackets for the pump, then we will see if it will go in the Speedtech subframe. GM put in a 11 rib for the blower which I like
161506
161507
RDeWild
02-14-2019, 12:28 PM
Thanks guys for the power window mfg./ wheel dealer recomendation.
Can’t wait to get this thing going. Hopefully work won’t get too crazy and I can still get it done this year.
Super happy with the Speedtech parts too. Very nice fab work from those guys!
GPRaceWorks
02-14-2019, 07:16 PM
Nice setup. I may have missed it, but what are you doing for the rear suspension? I'm going to be running the LT4 in my build, (just got the motor/trans delivery). I went with the SPEC chassis from Roadster Shop. Looks to be built extremely well. Just dropped it at the powder coating place today.
Can't wait to see how your project goes!!
RDeWild
02-18-2019, 10:31 AM
Went with the Speedtech extreme torque arm rear suspension with 9” rear on mine. Was looking at your build, your car is going to be super nice. I agree the roadster shop stuff is really nice!!
RDeWild
03-07-2019, 01:17 PM
Have an update today. Little brown truck showed up with the transmission. My trusty assistant Tyson Capone DeWild was helping me unwrap the box today. Cant wait to start jamming gears!!!!!!
162199
162200
162201
162202
162203
162204
andrewb70
03-07-2019, 01:21 PM
That is a very impressive piece of hardware!
Motown 454
03-07-2019, 01:26 PM
Wow that looks beefy! Beautiful machine work. My brother had a Boxer named Tyson, made me smile.
RDeWild
03-18-2019, 02:06 PM
Thanks MOTOWN, Weve always had a shop Boxer here. My old Boxer before Tyson was T-Bone. He would sit in front of the race car hauler before we would go racing. He never wanted to miss the races. So much personality with the boxers.
Have been making some small progress. Primer work being done on the underside and firewall with a bunch of sanding. Going with the flush mount glass, so im about to start modifying the pillars. This week were going to mock up the subframe and make mounts for the transmission. Got it up on the 2 post lift today.
Also finally received the LT5 stand alone , man those ecms are big!
As always Tyson helping out.
162582
162584
162583
162585
LT5 has 2 ECMs and a fuel pump controller
162586
andrewb70
03-18-2019, 02:13 PM
That e92 is a beast! Do you plan to put the computers in the engine bay?
RDeWild
03-19-2019, 12:20 PM
Going to try to hide them inside somewhere hopefully. Have quite a bit of room on the back side of the firewall. We will see though, this ECM is so much bigger. Mocking up the engine/bellhousing/transmission today.
162610
162611
162612
RDeWild
03-25-2019, 04:34 PM
Makin progress... starting to mock up some parts. LT5 went in there pretty easy, had to do some metal work on the subframe to clear the dry sump pan and 2 drain plugs. Transmission went in good, modified the back trans mount to fit. Shifter is in a good spot.
162885
162879
162880
162881
162882
162883
162884
Motown 454
03-25-2019, 06:23 PM
What an amazing build, those parts look so sweet in there! Nice work.
srode
04-30-2021, 03:46 AM
Any updates? I'm getting things sorted out for an LT5/Tremec in my 69 with a Speedtech extreme frame. Curious what you did the modify the firewall for the high pressure pump and where you are putting your oil tank. I'm tentatively planning on the battery tray and moving the battery to the trunk. Which front drive set up did you end up using for yours with the extreme frame?
