View Full Version : LS3 header options with mechanical clutch 69 Camaro
CROMAN69Z28
02-11-2019, 09:07 AM
Looking for a header recommendation for my Camaro. Z-bar is in the way. Anyone have an off the shelf option? I’d rather buy a header than go hydo. Thanks.
andrewb70
02-11-2019, 02:19 PM
The question begs to be asked. Why use a mechanical linkage?
CROMAN69Z28
02-11-2019, 02:26 PM
Because I already have it. Was running sbc with T-56 and have since built an LS3. I am still using the McLeod adapter and original linkage that has been there since I went 6 speed. I’d much rather find headers to work, or make some fit, than go through the pain of hydro clutch.
andrewb70
02-11-2019, 02:29 PM
The issue is that I don't know of any company that designed LS swap headers with mechanical linkage in mind. Most people that do a LS swap go with hydraulic clutch actuation.
CROMAN69Z28
02-11-2019, 02:49 PM
You are correct. At least it’s not a feature mentioned in any description. I know somebody has solved this puzzle before and hoping they will chime in with an easy solution. I have some eBay specials that I am planning to chop and tig if no other option is found. Basically crossing my fingers until I have time to cut them up and make my own.
