View Full Version : Detroit Speed subframe and frame connectors options not to weld them
nickburns
02-07-2019, 04:23 PM
Hey folks - I really don’t want to weld my subframe connectors to my subframe. I think I read that someone used bushing and bolts? Any pointers ?
thanks in advance
dhutton
02-07-2019, 04:30 PM
Pic of some nice custom brackets here:
https://lateral-g.net/forums/showthread.php?t=57083&page=6&highlight=Ironworks
Don
Gmachine1911
02-07-2019, 07:47 PM
I've got the DSE sub and connectors and welded the DSE brackets to the subframe and drilled/bolted them to the connectors. Before doing that, I drilled the connectors out and welded in 1/2" I.D. tubing to keep the frame connectors from crushing. Looks sanitary and works beautifully. I can post some pics if you need but lots of folks have done it this way so I'm sure there's pics floating around.
nickburns
02-21-2019, 10:32 AM
These are beautiful - I emailed Iron works to see if they can help out
nickburns
02-21-2019, 10:33 AM
Thank you @gmachine1911 - I wouldn’t mind seeing the pictures and if you could email me with any helpful info setting this up that would be great !
c4racer2
02-21-2019, 01:56 PM
They will work better if welded - more like the way modern car frames are built.
BackN70
02-21-2019, 03:40 PM
I'm diggin' these brackets.
Gmachine1911
02-21-2019, 07:31 PM
Here's the way I did it. Nothing that hasn't been done before...What you can't see is that I reinforced the subframe connectors where the bolt holes were drilled by welding in 1/2" I.D. tubing into the frame connectors to keep the from collapsing. A person could have plug welded the connector brackets to the connectors but if you ever have to get the subframe out of the car, it'll be a huge pain.
c4racer2
02-21-2019, 09:33 PM
Nah. Grinder will go thru the welds. How often do you replace the subframe ? Mine has been in place for almost 40 years now.
dontlifttoshift
02-22-2019, 02:22 PM
I have had 3 different motors in my 2nd gen in the past 24 months and have never taken the hood off, drop the subframe every time. It is the best part about having a subframe car.
I prefer the method shown above, simple, easy, solid. Done.
TheBandit
06-17-2020, 09:03 AM
For the spacer tubes, do you tack weld them from the inside of the tubing or are you somehow rosette welding them on the outside?
Gmachine1911
06-17-2020, 03:32 PM
Yes...both. 😀
