View Full Version : 69mustang coyote swap VSS
Shotaro
01-21-2019, 12:49 AM
I have 5.0 Coyote swap in 1969 Mustang. I am using the M - 6017 - A 504 V Ford Racing Control Pack, but the computer does not see the speedometer. The meter is equipped with Dakota Digital but the speedometer is not moving here. I think the transmission is MT 82. How do I put the speedometer VSS in my computer?160625160626160627160628160629
1bad68cat
01-21-2019, 07:27 AM
Just want to confirm first you are using a gen 2 coyote engine with the controls pack part number you mentioned? I only ask because the engine cover is Gen 1. The major visual difference between a Gen 1 and Gen 2 coyotes other than the engine cover is the charge motion control valves installed at the rear of the intake. If your engine is a Gen 1, I highly suspect that the controls pack is actually the Gen 1 part number M-6017-A504VA. There is wiring in the controls pack for the VSS already. Alos, FYI, Ford racing did have 2 versions of the Gen 1 controls pack. With and without the speed dial. The speed dial was added to combat stalling issues when coyote swapped cars came to a stop.
Shotaro
01-21-2019, 06:49 PM
https://www.factoryfive.com/wp-content/uploads/2012/08/Coyote-Speed-Dial-Instructions1.pdf <https://www.factoryfive.com/wp-content/uploads/2012/08/Coyote-Speed-Dial-Instructions1.pdf>
Do you think that this part is necessary?
https://performanceparts.ford.com/download/tipsPDF/Hot_Rod_Coyote_Swap_Guide_reprint_July_2013.pdf <https://performanceparts.ford.com/download/tipsPDF/Hot_Rod_Coyote_Swap_Guide_reprint_July_2013.pdf>
thank you
Shotaro
01-21-2019, 08:52 PM
160663160664I am thinking that my engine is 2011. I think that charge motion control valve actuator is not attached. The computer has 680540
Shotaro
01-22-2019, 12:37 AM
i think I will enter OSS directly into the control pack.
160665160666160667
1bad68cat
01-22-2019, 07:05 AM
thank you
Based on the picture of the PCM I believe you have Gen 1 controls pack, so I say yes. As a side note, Dakota Digital's website does not recommend the BIM-01-2 for the controls pack because it provides a limited amount of data.
Shotaro
01-31-2019, 11:32 PM
it was able to improve with only a foolish sensor.
