1976CamaroGuy
01-09-2019, 05:46 AM
I still have my 71 Camaro up on stands finishing up the brakes and a few other things. Last year it went through a major drivetrain and suspension overhaul. I haven't fired the motor or tried out the suspension yet...but I am close.
Things I have done:
1. Dropped in a 1998 LS1 / 4L60e that had 88k on it. Controlled by a Holley Terminator LS system.
2. Pulled all of the old suspension stuff off, which consisted of Moog springs, stock springs in the back, lowering blocks, stock cheap shocks, stock front and rear sway bars.
And replaced with Hotchkis front and rear dropped springs, CPP upper and lower tubular control arms, Adco 1-1/4" front sway bar, CPP 1" rear sway bar, CPP traction bars, Bilstein HD shocks.
Also have solid body bushings, CPP tubular subframe connectors, PTFB G-Brace, Cowl Brace and sway bar brace.
Steering components have been upgraded to forge, moog, and UMI tie rod adjusters.
Gear box is a borgeson 12:7.1 fast ratio box and upgraded the intermediate shaft to Jeep U-Joint.
3. Pulled the stock disc and drum brakes and stock MC / Booster and replaced with CPP C5 spindles and brakes, universal rear discs, Wilwood MC and Corvette dual 9" booster. Also upgraded all of the soft lines to braided stainless. Changed the stock 1/4" front to rear line to a 3/16" line.
Anyway that's the backstory on the upgrades and changes and can't wait to get the car on the ground, fired up and see how it compares to the old stuff.
But ONE thing I am on the fence about right now...shocks
Wondering if I should
1. Keep the Bilsteins and roll with it
2. Change them for the Hotchkis Fox tuned shocks to match my spring set-up
3. Buy a front coilover set-up for the front with dual adjustable front and rear shocks
There's pros and cons for any of the options...right now I am sort of leaning towards getting the fox shocks and keep the spring set-up.
But I like the appeal of having coilovers for the front...especially setting a tuned front ride height with minimal effort.
Oh and this is pretty much a street set-up...not planning to autocross, but I feel like the bug could hit me lol.
Open to any ideas or experiences you folks have had with these shock and suspension set-ups
Thanks in advance
Things I have done:
Thanks in advance
