View Full Version : Vintage Air on a 65 Malibu SS with LT1
76Stingray
01-03-2019, 02:06 PM
Im about to order a vintage air system for my 65 SS. Original AC car so im going to use the original controlls with their cable system. i just need to know which bracket to run with the compressor for the 96 LT1 stock f-body accessory bracket..its low mount but enough room for the small VA compressor. I also need the serpentine belt compressor instead of the v belt and wondering about the precut hoses.
Any help is greatly appreciated guys
dontlifttoshift
01-03-2019, 02:30 PM
You can run the R4 compressor or Vintage Air sells an adapter bracket for a Sanden compressor that _should_ work with your existing bracket.
Changing to a serpentine compressor is no problem when ordering.
You can order the kit with a modified hose kit, the compressor ends of the hoses will be left uncrimped and long so you can route and do what ever you need.
CapSS92
01-07-2019, 06:55 AM
I used a VA system with a stock LT1 compressor with no issues. I was using the B-body bracket system so I don't know what the difference is. The only issue I had was with the fittings. It took me a while to find something that fit and it was close but it worked fine for 25000 miles. I'll look at my stuff and see if I still have any of the fittings.
Alex
CapSS92
01-07-2019, 07:02 AM
Bowers Hot Rod shop also used to sell this bracket. They still list it so maybe you can check with them. I used the stock compressor as I bought a new one from Autozone with lifetime warranty. Just in case lol.
http://www.bowersrodshop.com/lt1-ac-relocation-kit/#!/Low-Hood-Style-LT1-A-C-Compressor-Relocation-Kit/p/1129965/category=335901
