View Full Version : Options for 3 point harness and 4 point cage
spacepirate
12-31-2018, 01:55 PM
I don't want to use a 5 point while just cruising around town and I wanted to see what others have used as a 3 point retractable harness that plays nice with a 4 point cage. It's a 68 Camaro and I'm running a Chassisworks 4 point roll bar.
I spoke with Morris Concepts and they make a set that utilize a D ring that you can weld to you cage. Has anyone done this?
Just want to weigh my options.
morrisclassic
12-31-2018, 06:39 PM
The d-ring has a hole thru the bracket , a 7/16 shoulder bolt goes thru it into a
bracket welded between two roll bar cross points or thru the roll bar. The d-ring assembly
can swivel on the 7/16 shoulder bolt.The d-ring is held on with a 7/16 shoulder bolt &
nut on the back side.
Thx, Billy
spacepirate
12-31-2018, 08:58 PM
Thanks for the clarification Billy. Hoping some fellow members have done this install.
