View Full Version : Exhaust Jig?
796spdbu
12-30-2018, 05:19 PM
Hey Guys,
I'm trying to find the company/product where you lay a jig over your "U" or "J" bend exhaust pipe and it will allow you to cut the tube accurately so when you build either a set of headers or an exhaust, it will look correct and transition smoothly. I did try to do a search in this section but came up with nothing. Thanks.
latoracing
12-31-2018, 06:55 AM
Check out https://www.icengineworks.com/ for the templates as they are very helpful for building headers and exhaust.
As far as cutting J or U bends accurately, I fabricated a block (UHMW for my purpose) that fit the inside radius of the bends. I used the block on a guided plate on my small bandsaw to cut the sections I need to replicate the "legos". There have been others who use abrasive chop saws or metal chop saws to get square cuts as well.
65 drop top
12-31-2018, 08:29 PM
Here you go, here are two different jigs. Sorry I can’t remember from who or where I saved these pictures from, but I liked the ideas so I saved them to my iPad.
jlcustomz
12-31-2018, 11:36 PM
159822
From a super chevy article on how to make custom headers. Could make one, they are for certain radius of bend per pipe size..
The 2nd pic above gives me an idea. Wanted to make a tabletop plate for portaband saw anyways. I can make a sliding jig with adjustable block to help hold pipe straight when cutting instead of just marking & eyeballing.
latoracing
01-01-2019, 06:55 AM
The second pic is from my build. Using the "legos" the block can be positioned...
159823
and the J bend can be positioned and cut fairly accurately. I did end up bolting some guides in place on my little table to make guiding the plate through the saw easier.
159824
I have several blocks that work with a bunch of different radii for all kinds of projects. The "legos" are not cheap, but well worth the investment in time saving and accurate modeling.
796spdbu
01-03-2019, 07:24 AM
159822
This is the one I was trying to remember. I read that article awhile back and couldn't remember where I read it. Now I just have to figure out who makes it or I may design one of my own. Thanks!
796spdbu
01-03-2019, 07:30 AM
65 drop top,Thanks. That top photo is an idea. Maybe I just make my own jig. Ice engine works makes something similar to the second photo. They are expensive.
796spdbu
01-03-2019, 07:40 AM
After I googled the Super Chevy article, I found out that Cone Engineering Makes the jig and sells a 4 piece kit for $80. I'll be purchasing this kit soon.
Thanks guys for all the help!
mklinger
01-03-2019, 04:38 PM
Here's yet another idea >
159893
