View Full Version : 416 First Gen Camaro Oil Pan
Nitrous
12-29-2018, 11:35 AM
Yet another person putting an LSA in a 1969 Camaro but I'd like the oil pan to be able to support a 4" stroke down the road. It looks like the Holley 302-3 oil pan can support a 4" stroke. Anyone used that?
The other options I was thinking was the Mast Motorsports LS Swap oil pan.
The last consideration was a Moroso High Clearance oil pan from brphotrods.
It sounds like with any of those options, since I'm already pulling the pan, I should also add an oil pump pickup tube brace/girdle and put that on?
dhutton
12-29-2018, 11:43 AM
Girdle not needed and won’t fit on that block/pump.
Don
Nitrous
12-29-2018, 12:49 PM
Don
Interesting good to know. Out of curiosity, what's different about the LSA setup with the pump and not needing the girdle?
dhutton
12-29-2018, 01:21 PM
The pickup tube has two bolts versus one on the earlier blocks.
Nitrous
12-30-2018, 05:57 PM
Any opinions on the pan options?
dhutton
12-30-2018, 06:35 PM
I used the stock LSA pan.
Nitrous
12-30-2018, 07:30 PM
In your 69 Camaro? I know when the previous owner put the LS1 in my car he had to notch the oil pan so that it would fit within the front subframe. I assumed the LSA crate pan would have the same issue but wanted to have a proper pan instead of one that was "customized".
badazz81z28
12-30-2018, 09:06 PM
Ls7 has a 4” stroke and pan is very shallow. I don’t see needing a special pan.
