View Full Version : Subframe level with rocker?
another69
12-29-2018, 08:32 AM
Should the subframe in 1st gens be the same level as the rocker panels? I'm asking because the rear of mine is slightly higher than the front. I can correct it now if that's an issue.
another69
12-31-2018, 12:13 PM
So I found some old GM drawings online, and it appears that the subframe should be level, but does not reference the rockers.
kush69
12-31-2018, 02:22 PM
i want to say the answer is yes. I just went trough this on a 68 camaro i changed the firewall and complete floor .Mock up as much as you can ,doors ,fenders ,rad support if its off you will see in the way gaps look thats how i went about it.
dhutton
12-31-2018, 02:37 PM
Solid subframe bushings?
another69
01-01-2019, 06:37 AM
Yes, solid DSE bushings. I may try to get the front bushings milled down a bit. Or just space the rears?
dhutton
01-01-2019, 06:58 AM
This brings up something puzzling I came across on the Camaro forum. The stock rubber bushings are a different thickness front to rear but the solid bushings are the same front to rear. Not sure if this is the cause of what you are seeing or not. If you installed a new floor it could also have a significant impact.
Sorry I only have questions and no answers.
Don
MuscleRodz
01-01-2019, 12:51 PM
It should be level, but if someone put a floor in it incorrectly, it may need to be shimmed to level. Only way to tell is to install ALL the sheetmetal and align it without attaching to sub. We have had to shim the mounts in the past to get everything to line up.
