View Full Version : Ford brake options?
zjolsen
12-14-2018, 06:16 PM
Wondering if I can get some help in picking out a brake solution for my 62 ford falcon. Car is being built for the occasional fast friday, but more of a friday night pro touring cruiser. Has TCI Mustang ll front suspension with viking crusader double adjustable coilovers and TCI 4 link with the same coilovers on a ford 9". No power brakes or steering, I do plan to put electric power steering assist (EPAS) on it. It has an aggressive cam (aka minimal vacuum).
Thoughts were:
Wilwood Dynapro 4 or 6 piston fronts
Wilwood Dynalite 4 piston rears
Wilwood Dual MC with value... diameter TBD.
My worry is that its still a manual brake vehicle... what options do I have? Powered brakes would be a possibility, but I worry I don't have enough vacuum to support it. No power steering, so a hydroboost type solution wouldn't work. I don't think a "super pedal" solution will fit my firewall. Just feeling lost on what options I have.
Any help is appreciated!
c4racer2
12-14-2018, 10:22 PM
Ok this js a loaded question and there is literally no simple answer on how to properly design a good performing manual brake system with reasonable effort, feel and clamping force.
The only thing I can say is none of those caliper options have adequate piston area to function very well as a manual system unless you can run 14” rotors Which I doubt.
You need PA of 5 or close to it.
And a very small front master bore too. And you typically need less front bore than rear so dual master isn’t a very good setup.
Either run hydroboost (not a fan) or get some help to design a proper manual system.
Caliper and rotor selection along with master bore size and pad CF are all very critical. And it’s not a one size fits all deal.
Twentyover
12-15-2018, 10:12 AM
On the European Ford Capri in my avatar, front suspension is based on an MII spindle. I'm grabbing the aluminum PBR's off a 99 Mustang V6, running (at Torbin K. of Kore 3suggestion) an 81 Firebird rear disk redrilled to Ford on the front to clear Kore3 MII hubs, and a 10.5 rear disc from the Mustang. I'm planning on using as much of the Mustang brkes as I can.
While I have nothing against Wilwood, want to run production car parts as much as possible for reliability and parts availability. I actually bought some D8-4 Wilwoods for the car before I throttled back to the easy button and used production parts
andrewb70
12-15-2018, 12:11 PM
On my 67 Cougar I use the Baer SS4+ system and it works great. Manual brakes, Baer Remaster 15/16" bore MC (low cost option is 74 Maverick 15/16 disk/drum MC). The added bonus is that the system comes with aluminum hubs, and everything is light weight, which helps with unsprung weight. The rotors also have aluminum hats. Also, check out my Cougar build for details about EPAS installation.
https://www.pro-touring.com/threads/109464-1967-Cougar-build-(over-700-pictures-and-videos)/page61
Starting around post #1203
RobNoLimit
12-18-2018, 07:34 AM
You may want to take a look at the Electric Hydro-Boost system from ABS Brake. We have used these on several cars and the brakes are amazing. Not a great choice for a short course car (too much brake, tricky to modulate the input) but awesome for a touring or cruiser.
zjolsen
01-07-2019, 07:39 AM
So I have been contemplating converting to power brakes using a vacuum assist pump. This would eliminate most of the hassle. I will still need to figure out bore size for the mc. Any preferred boosters or size I should use?
