DCx
12-12-2018, 02:57 AM
All parts are new and unused!
I made this EFI tank myself using a brand new 16 gallon gas tank. I went to the junk yard and bought a sn95 gas tank and cut the fuel mounting ring off the top and welded it along with the fuel basket into my mustang tank. I then bought a 1998 cobra efi fuel module with a 255lph pump installed. This unit will just drop right on in like it was a sn95 unit. It has -6AN fittings on the 3/8 feed and 5/16 return. you can even use the sending unit on the basket if you have the correct autometer gauge. if not bend the float arm on your stock unit and install it to block off the bottom of the tank.
This was my solution to an aeromotive stealth tank.
Asking $250
San Bernardino CA, Inland Empire
https://static1.pt-content.com/images/pt/2018/12/dWwhUns-1.jpg
https://static1.pt-content.com/images/pt/2018/12/35cVf0k-1.jpg
https://static1.pt-content.com/images/pt/2018/12/9iG6M8j-1.jpg
https://static1.pt-content.com/images/pt/2018/12/qKmgqm3-1.jpg
Asking $250
