De-noz
12-11-2018, 02:58 AM
After i install CPP's Hydroboost Kit https://static1.pt-content.com/images/pt/2018/12/clp6474hbksb_sn_ml-1.jpg I notice some brake and steering problems with this KIT.
I notice that the black adj. brake prop. valve that came in this Kit don't work properly - I can't lock the rear tires on a wet street...I also notice that a small leak at the adj. knob.it self...not sure if this small leak can be the reason.
I unscrew the adj. knob 159099 to see what's happened and found a O-ring seal which sits at the knob, question is now ...is there any other internal O-ring or other parts in the black block that's maybe damaged?
