toofun
12-09-2018, 10:16 AM
Bought this car from another member on here about 6 months ago. It was everything he said it was and more! I replaced the radiator that had a small leak in it, installed the inner fender wells and put some Fuel rail covers on it. I also cleaned up a lot of the wiring and made it safer for the trunk mounted battery by putting in a start em up kit and solenoid.
THIS CAR IS FAAAAST and man does it handle! Totally set up for Autocross and street. Just needs the interior to be completed and to paint the fenders and you can drive it anywhere. I love it, but miss my convertible so looking to get into a Convertible Camaro or other convertible muscle car. If you have something lets talk. Here is the list... A TON has been done to this car. It truly is awesome. I put about 1500 miles on it.
68 Camaro RS factory A/C car
L92 from an Escalade with 20k on it
Fuel Rail Covers
Wegner pullies and accessories
Cam and spring swap with LS3 intake
Drive By wire Lokar gas pedal
Vengeance Racing tuned car to run but not a dyno tune
Car dynoed 465hp at the wheels and gets around 22mpg on the road
T-56 Magnum with short shifter from American Powertrain
Strange 9" with detroit locker and 3.23 gears
DSE mini tub and 4 link rear
Ride Tech 2 way adjustable coil overs
Ride Tech Strong Arms upper and Lower
Stainless Works headers with Borla mufflers
Wilwood brakes and master cylinder
Hydratech hydro boost brakes
Ride Tech Tru Steer
6:1 quick ratio steering box
Budnik 18x10 and 18x11 wheels
BFG Rival 275 F and 315 R
Ricks tank with new camaro pump setup
Ride tech fuel cap
Finch Performance fuel vent
American Autowire complete new harness
Speartech LS harness
Vintage Air AC compressor installed on engine but everything else needs to be installed I have it all in boxes.
Dakota Digital Gauges
Idit polished steering column
Redline Lumtronix LED headlights with multi-color halo ring
C&R BRAND NEW RADIATOR Aluminum radiator with dual fans
Custom Aluminum radiator cross member
Custom hand stamped firewall
Custom underhood panels installed and color matched to the firewall and car.
2" steel cowl hood
Motor set back 3"s
Recaro leather seats
New carpet
Dynamat Extreme on floor and doors
It has custom flared front fenders that are all steel and in primer, I believe 315s will fit on the front and know a 295 will .
It doesn't have a headliner or interior panels. I have a leather covered rear seat also but it needs to be cut to fit the min-tub
Schroth 4 point harness also
$37,500
159058159059159060159061
$37,500.
Mark159053159062159063159054159055159056159057
Fuel Rail Covers
Ride Tech Tru Steer
Ride tech fuel cap
2" steel cowl hood
Motor set back 3"s
New carpet
$37,500
$37,500.
