View Full Version : LS Parts, Intakes, Comp Cams, Forged Pistons, Rods, Aeromotive, Throttle bodies
jwcarguy
12-04-2018, 08:07 PM
Have a bunch of LS /Vortec engine parts that will be not needing Prices include shipping from Las Vegas, NV (except crankshaft) I have a few complete LS3 and LS6 intake manifold setups: - Complete LS3 with seals, fuel rails w/ hold down bolts, fuel injectors w/ retaining clips, "gold blade" LS3/7 DBW Throttle body w/ bolts, MAP sensor and set of 10 GM intake mounting bolts (needed when converting from truck manifold)
$550 for complete manifold setup
- LS3 Intake manifold w/ port seals only, no map sensor, includes fuel rail, LS3 fuel injectors and set of 10 GM mounting bolts
$425
- Complete LS6 with seals, fuel rails w/ hold down bolts, fuel injectors w/ retaining clips, MAP sensor and throttle cable bracket ( LS6 dbc tb) and set of 10 GM intake mounting bolts (needed when converting from truck manifold) ( Have a couple cable throttle bodies available for extra $$)
Part # 12573572
$450 for complete LS6 manifold setup
- LS2 " Silver Blade" Throttle Bodies GM# 12570790
I have (2) available
(1) stock unported (1) has 3/16" hole in blade from tuner for idle
Pricing:
Stock TB - $220
Stock TB - $200 (w/ drilled blade)
- LS manifold (car intakes) GM mounting bolts (set of 10) needed when convert truck / Vortec to car intake $20/ set
- LS1 Forged Pistons and 5140 CNC Beam connecting Rods
Probe Industries " SRS" Sportsman Race Series Forged Flat top piston set 3.00cc
Part# 14217-003 w/ rings
for 3.902" bore ( .004" overbore on LS1), 3.622" stroke w/ .927" floating pin
and
Probe Industries CNC Beam 5140 Connecting Rods w/ ARP Wave Lock Bolts
Part #11662 with bronze bushings
low usage (see pics)
$480 for forged pistons & rods
-LS1/ LS6 GM bolt on Throttle cable Brackets w/ (2) mounting bolts
$25 ea.
- New Set of (16) LS7 Connecting Rod Bolts
GM part # 11609825
$120 for set of 16
-Comp Cams LSR Rectangle Port (large displacement) 3 bolt camshaft
part # 54-473-11 specs: 247/263, .624/.624 114 lsa
http://www.compcams.com/Company/CC/cam-specs/Details.aspx… (https://l.facebook.com/l.php?u=http%3A%2F%2Fwww.compcams.com%2FCompany%2F CC%2Fcam-specs%2FDetails.aspx%3Fcsid%3D1415%26fbclid%3DIwAR 3ChTPpyqQxTiq1v6UYwGQITMxdEc9s_KU79Jivo86DvOF3Bm-9t7ZTm4Q&h=AT0kEX3xz8O3eWZUIpwFKH71a0pEhWswEj_uLoMD3EQyNHWJ AjpHVX9oYyfQ8zMeA2Bmg93EOAI8I7HAXnOYHs6MqOO9GKdYPY Io2KJ4OmQTND7JIgPVBMc9LUjHtud1W6_SVx9GY5jXw18)
low miles
$300
- Gen V 6.2l L86 Crankshaft
part# 12623492
will need to be turned/ polished on rod journal
$80 (plus actual shipping cost)
- (2) used Aeromotive A750 "Tsnami" electric fuel pumps EFI
both will need to be sent in to Aeromotive for rebuilds
make offer $$
-LS Billet Ignition Coil Relocation brackets w/ mounting hardware
for LS2/3/7 coils
places coils towards center of valve cover
$50
-LS3/7 new take off round ignition coils w/ mounting brackets
no harnesses
$130
- LS3/7 5.3 , 6.2 used square ignition coils w/ mounting brackets & harnesses
$130
-Speedway Motors LS F-body Billet Alternator relocation (high mount) bracket
$85
- misc LS / Vortec stock valve cover sets available
more pics here: https://lasvegas.craigslist.org/pts/d/ls-parts-intakes-cam-pistons/6765079636.html
pm/call/text (702)677-4085
jamminj007
12-04-2018, 08:57 PM
Pm sent
jwcarguy
12-05-2018, 03:30 PM
Pm sent
pm replied
KAN KAN Speedshop
12-06-2018, 06:24 AM
PM Sent
jwcarguy
12-06-2018, 09:32 AM
PM Sent
pm replied
thanks
IMPALAMAN1
12-06-2018, 06:58 PM
Price on the pedal
jwcarguy
12-08-2018, 08:58 AM
Price on the pedal
I have them listed in separate ad, for some reason, I can't edit my ads??
Clayton Machine Works "Muscle car" series Mechanical Throttle Pedal assembly
new in box
Part # MCP-P1
$175 shipped
Clayton Machine Works "Muscle car" series DBW throttle Pedal pad
new in box
$80 shipped
C Presley
12-08-2018, 09:34 PM
I will buy the New LS7 Rod Bolts from you. 408 644-4610
jwcarguy
12-09-2018, 08:33 AM
PM sent
jwcarguy
12-15-2018, 06:09 AM
bump
jwcarguy
01-10-2019, 09:42 AM
bump it up
Mofoe73
01-10-2019, 12:09 PM
$130
How much if i make a trip to Vegas to pick them up?
jwcarguy
01-10-2019, 12:14 PM
$130
The used set of square ones are sold (I can't edit my ad for some reason?)
I just have the new set of round ones
$100 picked up
Jeff
jwcarguy
01-13-2019, 10:48 AM
The LS3 and LS6 intake manifold setups are all sold
jwcarguy
01-31-2019, 09:06 AM
I have one LS3 and a LS6 intake manifold setups available again
jwcarguy
02-01-2019, 10:12 AM
LS3 intake manifold setup and single Clayton pedal pad are SOLD!
