View Full Version : -4an 2in wide through frame fitting
Chuck0379
11-29-2018, 06:55 AM
Does anyone make these? I’m running -4 from the master cylinderr to the rear on my 68 Camaro and would like to use a -4 frame through fitting but can’t find one anywhere. I’ve found small ones about 1” wide by aueroquip. What are my options?
Chuck
BBPanel
11-29-2018, 07:16 AM
https://www.inlinetube.com/pages/product-list?itemNumber=thf02 I think this is -3, I'd check with them to verify and if they have same in -4. If you want -4 or -3 on both sides you could run and adapter on the female threaded side.
Chuck0379
11-29-2018, 02:31 PM
Thanks. I’ll check it out.
dontlifttoshift
11-29-2018, 02:50 PM
Don't run -4 to the rear.
If you are already committed, run -4 to any of the through frame fittings you have already found, install 1/8 npt x -4 adapter on the NPT side and then run -3 on the male outlet.
Chuck0379
11-30-2018, 02:41 AM
I’ve heard mixed reviews about running -3 or -4, but -4 is what I already have/factory and works good. Just installed a new 4 link so figured I’d keep it the same. What difference would there be if I ran -3?
dontlifttoshift
11-30-2018, 06:17 AM
The biggest difference is that you can buy a fitting that does what you need it to do.
