View Full Version : EZ clip ac hoses and fittings
68EFIvert
11-26-2018, 08:26 PM
I am going to use EZ clip ac and heater hoses on my car. I originally was going to use stainless Aeroquip fittings with braided hose but it is such a pain to work with I have changed my mind.
I think I will piece together a setup for the various fittings I need. Where does everyone buy their parts from? I generally go right to summit for things like this but am open to other vendors if prices are better. Thanks.
Anyone looking for some new Aeroquip fittings or hoses? LOL!
dhutton
11-27-2018, 03:15 AM
This kit has most of what you need for the AC side:
https://www.ebay.com/itm/Vintage-Air-E-Z-Clip-Refrigerant-Universal-Hose-Kit-547002-VTA-547002-VUR-547002/223171007431?epid=1543515886&hash=item33f60753c7:g:0WMAAOSwfr1bsmZ1
I ordered one of these knockoff kits because the price was too good to resist:
https://www.ebay.com/itm/Universal-134a-Air-Conditioning-Easy-Clip-Refrigerant-AC-Hose-Kit-Fittings-Clips/312226981885
Don
LemonTwisted
11-27-2018, 06:28 AM
Check hosewarehouse.com (https://hosewarehouse.com/field-specific-ez-clip-a-c-hose-and-fittings). Their prices should be a little cheaper if you can figure out what fittings you need.
CapSS92
11-27-2018, 05:05 PM
Try a heavy duty truck supply place locally. I had a place here in town order them for me at really good prices. I get a lot of fittings from VMACsINC on ebay too. Decent prices. The pliers are like $58 vs $80 from VA. For the hoses sometimes VMACs has a decent price and other times I just search around. Here's a couple of links. HTH.
https://www.ebay.com/str/vmacsinc
https://www.ebay.com/usr/coldmasterinc?_trksid=p2057872.m2749.l2754
Bad Bowtie
11-28-2018, 01:44 AM
Long time switcher to EZ Clip. Could never get double ended 45's or 90's to "land" where I needed them with the stainless Aero fittings, they were a pain. You really have to shop around on the prices.
BB
badazz81z28
11-28-2018, 06:07 AM
Don
Nothing against VA but they are stupid expensive on things like this. I guess that’s what happens when you don’t physically manufacture the product. You have to upcharge to make a profit. The EBay link is probably the same kit.
cpd004
11-28-2018, 06:14 AM
Definitely the way to go vs braided. I was able to piece together part numbers for a typical VA install with two different compressor fitting options. I'll see if I can locate it and post the link or part numbers here.
cpd004
11-28-2018, 06:24 AM
Here is the list I came up with copied from another post I made at this link: https://www.pro-touring.com/threads/123419-Custom-A-C-hoses-who-s-kit?highlight=aeroquip+clip
Hopefully this is correct...I went through the kit and tried to match up the parts at hosewarehouse.com:
If you go to page 4 here: http://www.vintageair.com/Instructions2013/907002.pdf
This where the hosewarehouse.com part numbers match up in order if I did this correctly.
1. GH134-06 (10')
2. GH134-08 (6' )
3. GH134-10 (5' )
4. 22546-11 (5)
5. 22546-13 (2)
6. 22546-15 (2)
7. FJ3013-03-0808S
8. FJ3012-02-1010S
9. FJ5984-0606S
10. FJ3055-01-0606S (2)
11. FJ5985-0606S (2)
12. FJ3055-030808S
13. FJ5984-1010S
14. 1F40105-06C (5 )
15. 1F40104-06C (10)
16. 1F40105-08C (2 )
17. 1F40104-08C (4 )
18. 1F40105-10C (2 )
19. 1F40104-10C (4 )
20. Grommet, Large (these should be the same as the ones included with the VA kit already unless I'm mistaken)
21. Refrigerant oil for hose assembly (will any do or something specific?)
The pliers and cutters are $52.81 & $35.19 as of this posting. They may be available elsewhere cheaper, but I haven't looked yet.
I haven't added the other parts up to see what the exact difference would be.
If anyone sees any mistakes, please let me know.
And then this update as I was installing it;
So far, #9 and #13 will not work with the evaporator. They are staright -6 and -10 as listed and should be 90's. I'm not sure if all evaporator units are the same, but for my 70-81 F-body kit, these should be :
9. FJ5985-0606S (90 Deg -6)
13. FJ5985-1010S (90 Deg -10)
The rest of the kit looks like it'll work, but no way to tell for a while as I'm not quite there yet.
Update:
All of this worked for me without any other additional parts in my 2nd gen LS equipped Firebird using a Kwik bracket and typical mounting system.
dhutton
11-28-2018, 06:27 AM
I got my $85 ebay kit. It is a Chinese knockoff but everything looks good aside from no caps on the service ports. Of course the true test is five years of use with no leaks etc.
Don
dhutton
12-14-2018, 05:24 AM
Ok so tried to assemble some hoses. The hose is slightly larger diameter than the Aeroquip hose and the -10 ring clamps deform when you try to assemble them. Tried some genuine EZ clip clamps but the hose is too large. Was able to assemble a -6 hose.
It seems there is no free lunch here.
Don
68EFIvert
12-15-2018, 11:36 AM
Bummer.
rickpaw
12-17-2018, 04:38 AM
One is a Chinese knock off, the other one uses Aeroquip hoses (not sure where the fittings came from).
Don
Then you know why the Chinese kit is $85.
Thanks for the update Don.
icemanrd19
12-17-2018, 09:03 PM
I think that might be the website I used. They were a 3rd of the price from summit. I tried finding a old invoice and I couldn’t
dontlifttoshift
12-18-2018, 05:25 AM
Maybe, almost, a third less but definitely not a third the price.
icemanrd19
12-18-2018, 05:22 PM
Just confirmed. I bought mine from hose warehouse. Summit had a fitting for $26 and hose warehouse
had it for $12. You will save a good amount of money buying from there
pist0lpete
01-07-2019, 08:08 PM
1. GH134-06 (10')
2. GH134-08 (6' )
3. GH134-10 (5' )
4. 22546-11 (5)
5. 22546-13 (2)
6. 22546-15 (2)
7. FJ3013-03-0808S
8. FJ3012-02-1010S
9. FJ5984-0606S
12. FJ3055-030808S
13. FJ5984-1010S
Update:
You the man thanks for sharing the list!
cpd004
01-08-2019, 05:36 AM
You're welcome. If you find other part numbers that work better in certain application, please post them.
Bmf5150
01-11-2019, 05:10 PM
Thank you for posting ,I’m about to install mine in the spring and I want to use the ez clip set
