View Full Version : Concept One Victory LS accessory drive system - Power steering, A/C, Alternator
VTtransam
11-25-2018, 03:36 PM
I have a Concept One Victory Series LS accessory drive system for sale. I need to get a more compact system to fit the air intake system I plan to run. This system has been great for 1,200 miles, and looks good too. Very high quality billet aluminum mounts. More information here: https://www.c1pulleys.com/collections/chevy-ls-victory-pulley-systems/products/chevy-ls-victory-series-kit-with-alternator-a-c-and-power-steering
Anodized black mounts
Polished SD-7 AC compressor
Polished Powermaster 120 amp, one-wire alternator
Power Steering pump set up for GM steering box, with billet reservoir
Black PTFE -6AN hoses with -6AN hose ends - correct length for 67-69 Camaro steering box (you will need adapters to box - DSE sells them)
Fluidamper SFI high performance harmonic dampener
Water pump and tensioner - both painted black to match
All original hardware
Belt
$2,700 new. Price is $2,000 shipped to lower 48. paypal accepted. If you want to pick it up near Pittsburgh PA I can do $1800.
158576158577158578158579158580158581158582158583
VTtransam
01-04-2019, 12:44 PM
Still for sale! Wish I could use this with my new intake setup but the alt and AC compressor are just a tad too tall.
souljaboy9768
01-04-2019, 12:50 PM
BUMp for nice setup!
VTtransam
01-14-2019, 08:00 AM
Had a few questions on why this won't fit my intake: I'm using a Harrop ITB manifold and the intake boxes take up a bunch of room above the valve covers, Alt and AC compressor on this set-up. The air box inlets slope downwards on each side towards the front of the car to clear a late model Corvette hood. It has been tough to match up components to my new intake set up but I think I have it sorted now.
This accessory drive should fit any stock or popular aftermarket intake.
badazz81z28
01-15-2019, 09:19 AM
Yes those accessories sit way high and wide for an aftermarket system. That cost is ridiculous too. That’s Vintage Air and Drive Junky territory. I would look into VA for ample clearance
VTtransam
01-17-2019, 06:13 PM
Similar product, similar price - all billet and anodized black. Good parts in good condition fetch 30% off new, shipped. Everyone is an expert though.
badazz81z28
01-18-2019, 09:22 AM
Copy that, I’m just saying thats why you would have clearance issues.
VTtransam
01-23-2019, 07:40 PM
Every aftermarket drive system would give me clearance issues with my new intake pictured below (I'm only using the airboxes attached to the ITB manifold). I've studied measurements of just about all the aftermarket drive systems. All had interference issues, or posed other problems in my set-up. This intake is designed for a late model corvette, so I needed a drive system that uses Corvette or F-body/GTO belt spacing with a remote power steering res. Other problem is I needed it to fit between a Speedtech Extreme subframe, third problem is I needed room to access my lines going to the PS rack. I've come up with a hybrid system using F-body spacing and a remote PS reservoir, plus a Holley low and tight mount AC compressor mount.
160705
Now back to the ad; price for the Concept One system dropped to $1800 shipped, or $1700 picked up. This drive system will fit any single throttle body intake.
Motor
01-25-2019, 05:06 PM
I am interested please give me a call to discuss David 6147838380 I am in Columbus Ohio
VTtransam
03-14-2019, 05:00 PM
Still for sale: $1500 shipped, $1400 picked up near Pittsburgh PA.
souljaboy9768
03-14-2019, 07:30 PM
Will this work with my LS1 if so, PM me
VTtransam
03-15-2019, 03:28 AM
This will work on an LS1, PM sent.
Motor
03-15-2019, 10:03 AM
Hello this is David again please call me at 614-783-8380 thank you
bmiller
03-24-2019, 08:33 AM
Is this still available?
VTtransam
03-25-2019, 04:48 AM
Yes it is.
VTtransam
04-02-2019, 02:56 AM
Sold
