classiccarcustoms
11-25-2018, 03:11 PM
I have some leftover take off part from my 1969 Camaro. Also a couple things in there for 68-67.
1. Pair of used upper Global West tubular upper control arms. $350. (1967-69 Camaro)
2. Pair of lower global west tubular control arms . $520 (1967-69 Camaro)
3. Pair of front QA1 Coil over conversion single adjust with 450 pound springs. $375 (1967-69 Camaro)
4. C4 corvette calibers. $145.00 pair Pair with out mounting brackets, $100.
5. CPP quick ratio power steering box new idler arm new Pitman arm in an outer tire rod ends and Hotckis adjustable sleeves. $600 (1967-69 Camaro)
6. 1969 Camaro lower portion of the center console. This is an original piece with no cracks in great condition. This is the lower portion of the Console only. Upper is included, but in bacd shape . $75.00
7. 1969 Camaro factory speedometer and factory tachometer with lenses in great working condition (original) . $350. If you want the new bezel (after market). Add $175.00
8. 1968/69 Camaro Center console 4 gauge pod and wiring harness and bezel. (after market) $300
9. Rebuilt 197 to 402 Chevy big block complete. Also comes with a turbo 400 complete. Sold
10. First Jen Camero small block headers. $65. (1967-69 Camaro)
11. Factory 1969 Camaro rally wheels and original derby caps. Great BFG Goodrich 225-60-15 tires. 15 inch. Set of 4. .
$700
12. 1969 Camaro 12 bolt Posi rear end.
Multi leaf spring pads. Mosher big axles with half inch wheel studs this unit is clean and rebuilt only 500 miles on it . $2,200
13. 1967/68 vintage AC underdash evaporator box and miscellaneous bezels and hoses. This unit came out of my 68 Camaro it was in great working condition. It is the evaporator underdash box hoses some bezels that is it . $200 Older unit, uses factory controller cables, not electronic.
14. 1969 Camaro original standard Grille in great condition four original house one small crack. $90
15. 1967/69 Camaro original flat hood in great condition. $50
16. First GEN Camaro hood hinges powder coated black. For the pair. $85
17. 1969 rebuild steering column. Non-tilt floor shift. $200
18. 1968/69 Camaro window regulators front and rear. Standard interior.
$100
19. Monro rear shocks. Complete with all mounting hardware. $50 for pair 1969 Camaro
20. CPP chrome brake master cylinder with 4 wheel disc proportioning valve .
$125
Parts located in San Jose CA
NOT looking to ship at this time. Local pick up only.
$700
$100
$125
