View Full Version : Is my compressor fixed or variable displacement?
jasonz28camaro
11-13-2018, 05:58 PM
I have a 2018 L86 motor and i was wondering how i can Lookup to see if my compressor is fixed or variable displacement? I’m assuming it’s cariable but thought I’d try to look into it. Here’s a photo of the compressors tag.
https://static1.pt-content.com/images/pt/2018/11/37F440E9A97C4C3DB3213FEC46598266_zps6nnw-1.jpeg (http://s151.photobucket.com/user/jasonz28camaro95/media/37F440E9-A97C-4C3D-B321-3FEC46598266_zps6nnwwd9s.jpeg.html)
Vintage Air tech.
11-16-2018, 12:16 PM
These compressors are most likely Variable displacement, The replacement compressor for the 2018 L86 is a variable displacement. Some visual indicators to I.D the style is:
Variable displacement comps will typically have a displacement control valve on the body of the compressor (on sides or rear)
Also in some models there will be an electrical connection going to a pressure switch that is built into the compressor, not to be confused with the power wire.
Fixed displacement compressor will only have one electrical connector and will not have a control valve.
Evldoer
12-17-2018, 02:26 PM
Here is what you need to do to make it a fixed displacement compressor.
On the rear of the compressor there is a wire connector. This is for your variable displacement valve. Tie this wire into the compressor clutch energize wire. (+)
Your done. When clutch is turned on it also opens the solenoid. Works great. I have done 2 gen 5 swaps with a/c and this is how I set them up and they work perfect. Good l u ck
jasonz28camaro
12-28-2018, 12:23 PM
Thanks man!
danielburko
12-20-2023, 02:15 PM
Did you get the variable ac converted to fixed as per what was mentioned above?
