View Full Version : 2010+ Camaro Module wanted (top)
badazz81z28
11-11-2018, 11:40 AM
Looking for a super cheap in-operative 5th Gen Camaro fuel pump model. All I need really is the hat so I can fill a fuel tank with water to see where it’s keaking. Please lmk.
reedld
11-13-2018, 11:54 AM
I dont have one but I have heard the HHR pump diameter/mount is the same. Finding one for an HHR may be cheaper and easier to find in a salvage yard.
Good Luck
andrewb70
11-13-2018, 05:00 PM
Carl made a post about this somewhere...basically, many cars use that same hat. Check on Rockauto for pictures. Try Impala, Malibu, etc...trucks...around 2009.
badazz81z28
11-13-2018, 06:18 PM
Ahh, yeah I can try the pick and pull if another car uses the same size hat.
dontlifttoshift
11-14-2018, 05:22 AM
Unsolicited advice. Water won't leak where gas will.....plus it's a pain to get all the water out of the tank.
Use compressed air, tape up all the holes, you can even leave your fuel pump in, and blow some air in the filler neck. Not a lot, you are not trying to pressurize the tank much over 15 psi, then use bubbles to find your leak.
