View Full Version : Camaro SS 4 piston calipers
Titan1021
11-01-2018, 05:26 PM
I have a 68 camaro with drums all around. I’m going to be installing some 4 piston Brembo off a 6th gen camaro. My question is what type off MC should I go with. I was thinking of going with a wilwood tandem MC. And adding a residual pressure vale for the drum rears. Just to note. I plan on adding rear disk some time in the future. Any help would be appreciated.
andrewb70
11-02-2018, 04:34 AM
Don't need a pressure valve in the rear. Are you doing manual or power brakes?
dhutton
11-02-2018, 05:27 AM
Pretty sure a 10 psi RPV is needed for rear drums....
Don
andrewb70
11-02-2018, 06:04 AM
Don
Why? I thought those were only needed when the MC is mounted lower than the wheel cylinder?
dhutton
11-02-2018, 08:54 AM
Rear drums need some preload on them or they will not brake effectively. The preload keeps the pads just kissing the drums.
Don
Titan1021
11-02-2018, 09:02 AM
They are manual brakes. And will stay that way. Is there a way for me to use the original master. With the new disk brakes.
67King
11-12-2018, 09:22 AM
I would fully expect that you will be moving a much greater volume of fluid with 4 pistons each with, say, 40mm or so diameter versus 2 with about 12mm, and that the result would be that you'd need a larger bore MC. MAYBE a Corvette one would work, but still look the same. I have Corvette brakes on my GTO, but I don't think the pistons are all that big. Been a long time since I had them apart. The bore size difference is 1.125 compared to 1.000 for the drum brake cars, which is a little more than a 25% increase in fluid moving capability.
