View Full Version : 1957 Chevy pro touring build
00SNAKE530
11-01-2018, 01:09 PM
I wanted to share my 57 chevy pro touring build with the forum. The project started a couple months ago, so I will catch you up and try to keep the tread updated as it progresses. The car is a 1957 chevy 210 (VB) vin California built in Van Nuys. The Body was rotisserie sandblasted then primed with PPG DP90, The chassis was sandblasted and coated in POR15 and topcoat. The car has Ridetech coil-overs with remote reservoirs front and rear with Ridetech Strongarm control arms and muscle bar up front with Heidts 4 bar, sway bar and loaded 9" in the rear. Flaming river rack and pinon. Brakes are 6 piston 2 piece discs up front and 4 piston 2 piece discs in the rear. The wheels are billet specialties 18x8 and 20x10 on bridgestone potenza s001 tires. The engine is a ls1 built by redline backed by a 4l80e. Fitech intake, throttle body and engine/transmission management. At this stage im trying to wrap up the fuel system, wiring for chassis and engine management, vintage air and power steering lines, and panel fitment. Enjoy. 158002158001158000157999157998157996157997
slazisme
11-06-2018, 07:05 PM
Looks like a solid foundation to start with, keep the posts coming, I have a Fitech computer & harness that I'll be using for when I convert to LS platform so I might learn a few things along the way. The valve covers add a nice bit of nostalgia.
00SNAKE530
11-14-2018, 12:46 PM
Thanks. I'll keep you posted on the Fitech, should have the engine running in the next few days.
DT69Cam
11-14-2018, 01:37 PM
Very Very Nice!!
andrewb70
11-14-2018, 02:31 PM
Cool build!
00SNAKE530
11-14-2018, 06:17 PM
Cool build!
Thanks guys.
Andrew, i noticed you sig and thought you might like this. 1970 GTO, factory ram air 3, 4 speed, 100% original sheetmertal Arizona car, QA1 coil overs front and rear, tubular control arms and large sway bars front and rear with ssbc brakes. Year one wheels. All factory parts to return to 100% original if ever needed.
andrewb70
11-14-2018, 07:08 PM
Looks a lot like mine!
jaybee
11-18-2018, 06:14 PM
That's going to be a great car.
rat_rod_russell
11-19-2018, 03:18 PM
If that's your shop, I have to say I'm in love with your high windows and brick. Killer 57 As well. I always miss my Black Widow when I see a new 57 build. Keep up the awesome photos. You obviously know how to color balance and I enjoy good composition almost as much as I love killer builds so keep up the good work.
00SNAKE530
11-20-2018, 06:17 AM
Thanks, I've had thoughts of switching the car over to 150 trim and absolutely love the car in the link below. If you have pictures of your car I love to see them.
https://www.fuelcurve.com/tri-five-chevy-150/
ragtopdodge
11-20-2018, 11:26 AM
I dunno. That trim reminds me too much of 1955 trim.
rat_rod_russell
11-21-2018, 11:41 AM
You really want to screw up someone's day, show them a 56 150.
158453
https://www.youtube.com/watch?v=fqWyz2b475Q
158456
158455
158457
158458
158459
158460
158461
158462
Later,
-Russell
00SNAKE530
11-22-2018, 09:20 AM
158453
158456
158455
158457
158458
158459
158460
158461
158462
Later,
-Russell
Awesome, thanks.
00SNAKE530
11-22-2018, 09:27 AM
This weeks progress.... To keep the frame rails clean the fuel and battery lines were run inside the frame, custom radiator lines were made with polished and bead rolled aluminum tube secured with shrink clamps and the rear shock reservoirs were mounted.
minendrews68
11-22-2018, 03:01 PM
Sweet!
00SNAKE530
12-07-2018, 03:21 PM
Working on the exhaust now, building the system from scratch using 304 polished exhaust tubing and magnaflow polished muffles. Everything is first tacked together and assembled, then final welding and finish polishing. I took 4 pictures from start to finish of the same joint.
159008159009159010159011
00SNAKE530
01-14-2019, 06:44 PM
Few updates, have the exhaust finished back to the rear end, Fired the engine up for the first time and roughed in idle settings, lokar shifter and gas pedal installed, steering finished, Dakota digital rtx gauges wired and drove it around my parking lot. Here's a few pictures of the exhaust.
