classiccarcustoms
10-30-2018, 06:51 PM
This is hands down one of the nicest 1955 Nomads on the streets today.
It has gone under a complete frame off restoration. All body panels were painted off the car inside and out. The under side of the car has been painted with a bed liner material that was tinted the same color of the car. The original frame was sent sand blasted and powder coated black. All the stainless steel and chrome were sent out and redone and is in like new condition. All the body panel fitment and finish are impeccable.
Interior was redone in a beautiful tan leather that enhances the original style while including a factory style radio with 6 speakers and amplifier for an amazing sound system that is all hidden.
Vintage Air heating and ac.
Ididit steering column with billet steering wheel.
Classic Instrument gauges.
Complete modern wiring harness front to back.
Coys 20inch wheels front and rear. New front..245/35/20 and rear tires..275/35/20.
Professionally applied Ceramic Pro 9H bond to the vehicles entirety.
Drive train:
GM all aluminum LS3 with mild cam and tune work. Built by Texas Speed and performance. 515hp.
True-Trac Billet serpentine belt set up.
GM crate 4L65E overdrive automatic transmission.
Custom drive shaft.
Texas Speed stand alone wire harness. With Re flashed ECM.
Texas Speed air Filter assembly.
Texas speed engine mounts.
Factory GTO Exhaust manifolds, sent out and coated, out to factory GTO resonators then out to a single muffler all the way out the back. Sounds amazing.
Relocated ignition coils.
GM performance Valve covers.
Cooling
Bolt in Billet aluminum radiator suport.
Customs aluminum LS retro fit radiator with dual cooling fans, controlled by the computer.
Aluminum a/c condenser and steel breaded a/c lines to match.
Suspension and brakes
Ridetech Tubular upper and lower control arms.
Ridetech coil over front shocks.
4-link rear suspension with custom narrowed ford 9" rear end.
QA1 rear coil overs.
Flaming River power rack and pinion .
6 piston 13inch Wilwood front disk brakes.
4 piston 13inch Wilwood rear brakes.
All brake lines are stainless steel.
Location is San Jose CA
Price is $94,000
Might trade for 69 Camaro corvette chevelle diesel truck, c10
Drive train:
Custom drive shaft.
Cooling
Price is $94,000
