View Full Version : Tilt Column, 69 Camaro 69-72 A-Body
birdsandbowties
10-27-2018, 10:34 AM
I have a tilt i just finished assembling this morning , it is done in satin black with billet levers
this column fits 69 Camaro with use of a coupler on end of steering shaft and fits 69-72 Chevelle and other A-Body cars as it is , needs nothing else for install
$550.00 shipped and can be shipped monday morning
I have two of these finished, 850-382-7125 , Jim GMTilt.com
cdrod
10-28-2018, 05:34 AM
Jim:
Tell me what goes into your rebuild. New bearings, turn signal switch/cancel cam, new key & tumblers, etc??? Thanks!
Rodney
birdsandbowties
10-28-2018, 05:55 AM
Jim:
Rodney
new ign switch, new turn switch,cancel cam and key tumbler, new lower bearing adapter and i have new bearings for the columns they make them for , some are not reproduced
cdrod
11-11-2018, 07:05 AM
Jim,
Thanks for the info. I'm ready to pull the trigger on an A-body tilt column, but I have two more questions:
1. Does it have the neutral safety switch in the column?
2. How difficult is it to add & "clock" the shifter arm assembly to the end of the column?
My car is a '72 Olds 442 with floor shifter, but I think the neutral switch is in the column. Never done this before just looking for a little reassurance.
Rodney
birdsandbowties
11-12-2018, 03:58 PM
Jim,
Rodney
i can build the column with the neutral lever no problem so it can be hooked to the trans , i can put the switch on the lower part , i have them and the right clips , i will pm you, thanks, Jim
