View Full Version : QA1 A arms
mnr60
10-25-2018, 06:19 AM
I have QA1 A arms to install, which way would be better way to install for a daily driver?
68 Camaro
QA1 upper control arms have eccentric cross-shafts.
A. This side of the cross-shaft with the shallow cutout will allow for a factory alignment.
B. This side of the cross-shaft with the deep cutout will allow for additional negative camber.
Jimmy Sean
10-25-2018, 09:44 AM
Option B.
From QA1's site "All of the upper arms feature an offset cross shaft letting you quickly and easily adjust camber.
All of these arms are designed to add 3-4 degrees of caster and 0.5 to 1 degree of negative camber when used together. When used independently they will add approximately half of the preceding numbers."
mnr60
10-25-2018, 09:59 AM
Thanks!
davidmar
10-25-2018, 10:33 AM
If I were to go with option B would the deep cut out face the engine or the tire? Thank you. Good timing--installing this weekend. 157796
mnr60
10-25-2018, 11:41 AM
Good question!
I assumed it would go toward the tire.
Let's wait for more knowledgeable people to speak up.
Jimmy Sean
10-25-2018, 12:17 PM
Deep cutout faces the tire. Here are the instructions. http://www.qa1.net/tech/documents/GM%20UCA_REV_11-15-2016.pdf
mnr60
10-25-2018, 03:43 PM
Thank you
davidmar
10-25-2018, 03:48 PM
Thank you. Could be just me but the link didn't work.
mnr60
10-25-2018, 04:57 PM
worked for me, just had to wait a minute or two (my computer is slow)
