View Full Version : 5th Gen brakes on 1st Gen Camaro
jgeddes
10-20-2018, 02:28 PM
New to the site and looking for a little help.
I have a 2011 Camaro that I am using as a donor car for my 1968 Camaro project.
I’d really like to use the breaks off the 2011 but most of the forums I’ve read indicate only the ZL1 brakes will work unless you can somehow fit 20” wheels which I’m not really trying to do.
Does anyone know of a relatively easy way to make the breaks fit?
Also going to be pulling any other parts I can feasibly use so if anyone has done this and has any other suggestions feel free to share.
157654
157655
CapSS92
10-22-2018, 08:22 AM
Other than the interior,engine, and brake calipers I don't think there is anything else you can use. The rear end is too wide from what I hear and I haven't seen anyone use anything from the front suspension. Search my name for posts and you can see some pictures I put up in regards to installing an interior. The front seats will fit but you will have to work on the floor for clearance. Other than that here's some links for reading on brakes.
https://ls1tech.com/forums/conversions-hybrids/1642686-2010-camaro-caliper-rotor-setup-early-body.html
https://ls1tech.com/forums/suspension-brakes/1867771-5th-gen-zl1-brakes-4th-gen-camaro.html
https://www.pro-touring.com/threads/112702-5th-gen-camaro-brakes-on-a-2nd-gen-camaro
http://nastyz28.com/threads/2010-camaro-ss-calipers-how-to-fit-to-2nd-gen-spindle-of-cpp-c5-c6-new-spindles.256330/
http://flynbye.com/catalog/c5_p1.html
http://bigbrakeupgrade.com/
