View Full Version : Billet wheel Flex
nc69rs
10-13-2018, 05:03 PM
How much flex have you guys seen during autocross of road course ? I did a autocross today and my wheels moved 3/4 inch to make contact with the coilover bracket.
Mr Nick
10-13-2018, 05:33 PM
Is the picture showing metal shavings from the rim, or just scuffed rubber on the tire sidewall?
nc69rs
10-13-2018, 06:17 PM
That's metal shavings were the rim made contact all the way around.
oleyeller
10-13-2018, 08:37 PM
That begs the question... What wheels are you running?, what rear end?
dontlifttoshift
10-14-2018, 06:38 AM
....and what did it rub on? Picture is unclear.
nc69rs
10-14-2018, 07:10 AM
Budnik 18X12
12 bolt rear I measured 10-15 thousands end play per side
The wheel hit the lower coil over bracket.
nc69rs
10-14-2018, 07:27 AM
Better pictures I hope, you can see in one where the tire was rubbing on the actual coilover.
I have now modified the bracket to avoid further contact with the rim.
BlackHD
10-14-2018, 08:34 AM
What did you do to fix it?
65 drop top
10-14-2018, 06:37 PM
Man, 3/4” of wheel flex sounds like a ton to me. Are you sure it’s not the coil over bracket that is flexing?
oleyeller
10-14-2018, 07:55 PM
What tire and air pressure were you running. I can see the tire moving over, but the wheel? That just seems like a lot..... Mine is closer than yours but I have not leaned on it that hard yet,..... you have me interested in changing my lower shock mount.
nc69rs
10-15-2018, 02:47 AM
I am running Rivals, 32 psi. I am surprised at the movement too, it seems excessive that's why I'm asking.
I thought with the bracket being steel if it moved that much it would bend.
79T/Aman
10-15-2018, 10:04 AM
you have the wheel flexing in and the coil over pushes out on the bracket, so a little flex from both and "voila"
egoman
10-15-2018, 05:17 PM
Does this car have a floater or a standard flanged or c-clip axles. If not a floater you can get a fair amount of movement with standard style rear ends. Combine the flex in several areas and that could explain your problems.
nc69rs
10-15-2018, 05:24 PM
I am going to mount a GoPro for this weekends autocross and see what's going on.
79T/Aman
10-16-2018, 06:11 AM
looks to be on a stock GM housing, cut yourself a 1/4" plate to go between the spring perch and the lower bracket plate, or an aluminum block to fill the void where the leaf spring was.
nc69rs
10-16-2018, 01:44 PM
It is a stock housing. Ridetech said they run the same setup with as little as 3/8 clearance and no rubbing.
FlyDoc
10-16-2018, 05:48 PM
I want to see the go-pro video!
AU Doc
10-17-2018, 07:29 AM
^^^^ What he said!
