View Full Version : New: Hellcat Supercharger Intercooler Manifolds - Billet
Schwartz Performance
10-10-2018, 02:05 PM
Schwartz Performance is excited to announce a new product we've developed specifically for the Hellcat/Demon superchargers.
Hellcat Supercharger Billet Intercooler Water Manifolds by Schwartz Performance
Make your Hellcat swap a little easier by ditching the large cast intercooler manifold on the factory Hellcat / Demon superchargers, and replace with our exclusive billet adapters!
Our low-profile manifolds are over an inch shallower than the factory Hellcat piece, NOT INCLUDING the pesky temp sensor that sticks off even further!
With our manifolds, you can choose your own path for the intercooler hoses, and use #10 AN hose instead of ugly rubber hose or attempting to adapt factory hoses. We allow use of the factory temp sensor and bleeder valve for OE functionality.
Our base kit includes:
-(1) LH and (1) RH billet aluminum manifold
-(4) #10 AN to O-ring adapters
-(1) #10 AN to NPT fitting adapter for temp sensor
-(1) 1/8″ NPT allen plug
-(1) #10 O-ring low profile allen plug
OPTIONAL ADD-ON:
-(2) Assembled #10 AN hoses for connecting the two manifolds together
***You will need to furnish the in/out side of the manifolds to your reservoir/pump/heat exchanger using #10 AN O-ring adapters of your choice.
Straight or 45 degree swivel adapters will work, with a 90 or 45 degree hose end attached.***
ITEMS TO REUSE OR SOURCE FROM A PARTS STORE/DEALER:
-(1) Mopar water temp sensor
-(1) 1/8NPT bleeder
-(4) Torx button head bolts
MSRP: $475
Add $45 for rear connecting hoses ($520)
To order, visit
Schwartz Performance - Hellcat Intercooler Manifolds (http://www.schwartzperformance.com/product/hellcat-supercharger-intercooler-manifold-adapters-billet-aluminum-an/")
Or call (815)206-2230
https://static1.pt-content.com/images/pt/2018/10/30920069668_857e12d8ae-1.jpg
https://static1.pt-content.com/images/pt/2018/10/30920069928_f2f754d307_z-1.jpg
https://static1.pt-content.com/images/pt/2018/10/44071360454_dede6fda47-1.jpg
https://static1.pt-content.com/images/pt/2018/10/45183243622_4d8952de05_z-1.jpg
